mrz
Built in function library
Thu Mar 08, 2018 4:56 pm
We are considering to add commonly used functions as built-in.
What functions would you like to see?
For example, MD5hash, random number generator and so on.
boen_robot
Re: Built in function library
Thu Mar 08, 2018 5:22 pm
From most important to least importing in my opinion:
String replacement. Both by a string needle, and a regex match.
String splitting (into an array of strings). Both by a string needle, and a regex match.
Joining strings in an array into a single string with a specified string between each array member (implicitly convert array values with ":tostr").
Date and time manipulation functions, such as returning the difference between two dates as a "time" value, or adding/subtracting a "time" value to a date (or "num" that is treated as plus seconds), to get a new date at that offset. Also timestamp convertion, i.e. a function to convert a "num" value to a date and time from the unix epoch, and convert a date to a "num" value that is such a timestamp. Being able to output the date and time in a different format would be nice, though it should always default to RouterOS' current format. To that particular end, it would be awesome if there are two new scripting types - date, and datetime, to complement the already existing "time" type, along with type conversion functions. Places within RouterOS that have dates and datetimes should be updated to return typed values instead of strings.
String encoding and decoding functions. Notably, a function to convert a number to a character in a charset (defaulting to ASCII, should support at minimum that and UTF-8), and vice versa. Some other commonly used encoding schemes, such as raw URL encoding/decoding, hex encoding/decoding, hex encoding with a "\" (when generating RouterOS scripts) would also be great.
Array manipulation functions. Such as a function for unique values in an array, getting the key at an index (return "nothing" if there isn't one), sorting an array by key (with an option what to do for keyless members), or by value, in either ascending or descending order, ideally with the option to specify a comparrison function.
In addition to MD5, SHA1, SHA256 and any other OpenSSL supported hashes would be nice, for the purposes of computing hashes to either be posted to a 3rd party or comparing 3rd party checksums. On a related note, encrypting, decrypting and signing data (strings and files) with certificates in the "/certificate" menu (ala PGP) would be awesome.
In addition to a random number between two values, a "random bytes" function (where you just specify the number of bytes you want) would be nice too.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Joni
Fri Mar 09, 2018 8:52 am
If you want to really jumpstart the Mikrotik scripting community then you should probably review the php most common sought after functions.
Also review scripts made for Mikrotik and the most commonly created functions there.
Personally any and all validation functions (ip, dns, email, url, time, date, etc) would be extremely helpfull for anyone trying to implement anything.
(disclaimer, this has nothing to do with php itself but the most adopted language by beginners, cant argue with history)
boen_robot
Mon Mar 12, 2018 5:15 pm
Oh, oh... one more important idea... A function to show the type and value of a variable. When outputting strings or arrays, include lengths, and when outputting strings, surround them with quotes and escape quotes, slashes and unprintable characters inside (so that what's shown could potentially be copy&pasted into a script or parsed). Something analogus to PHP's var_dump(), except that arrays will be shown with both indexes and keys (since RouterOS arrays can have both, whereas PHP can only have either), and perhaps return the string instead of outputting it on screen (allowing users to send it, store it in a file, etc.; not just output it on screen).
This same function, in addition to being useful when debugging scripts, will also enable RouterOS to output reliably parsable data from "print as-value", as opposed to print's other formats, that can all be broken if the user has set a certain value to a free form string field (e.g. comment).
nz_monkey
Mon Mar 12, 2018 10:56 pm
I was about to post what I thought was important, then realized boen_robot has written everything I was going to :D
So +1 to everything he said..
http://thebrotherswisp.com/ | Mikrotik MTCNA, MTCRE, MTCINE | Fortinet NSE7 | Extreme Networks ENA
Joni
Tue Mar 13, 2018 9:48 am
You could also take into consideration the future possibility of executing scheduled remote scripts from The Dude on remote Device.
(ex collect backups from monitored devices)
anav
Tue Mar 13, 2018 1:41 pm
Easy, a function that creates Ports/Services groups, which then can be used in port forwarding and firewall rules etc........
I'd rather manage rats than software. Follow my advice at your own risk! (Sob & mkx forced me to write that!)
MTUNA Certified, by the Ascerbic Llama!
pe1chl
Tue Mar 13, 2018 2:00 pm
I fully agree with that!
ivanfm
Tue Mar 13, 2018 7:01 pm
My suggestions :
ISODateTime - returns date/time in ISO format, great for saving backup files, that can be ordered, currently the ROS date used month as text.
FlashPrefix - receive an filename and return it with /flash/ when the device has an /flash directory to keep saved files
Function to keep only some characters from string (used to create safe filenames)
Replace characters on string , given an string, old character and new character all old characters found in the string are replaced by new character
Modulus of division (better to be an operator instead of function)
function to sort an array, by ascii strings or by numeric values.
hash function returning values in hex.
omega-00
Wed Mar 14, 2018 2:27 pm
1. The implementation of a switch function as an alternative to if,else.. or at least if,elseif,else.
2. Add back in the LUA support for editing items/utilising datasets above 4k characters long.
3. A random function would be very handy
4. All the things boen said.
A better debugger would also be nice, but now I'm just being picky. :-)
brightwifi.com | mikrotik-routeros.com | MTCNA,MTCWE.MTCTCE | Give karma where due
thobias
Thu Mar 22, 2018 12:01 pm
Date/time comparison (NOW();) and option to get time in different formats.
Json parsing.
LUA or whatever to be able to parse larger files.
armandfumal
Thu Apr 12, 2018 8:51 am
url_encode();
Armand Fumal
________________________________________________________________
MikroTik & Ubiquity
Chupakabra303
Wed Apr 18, 2018 1:55 pm
LUA +1
Internal JSON parser to associative array variable (by type http://www.embest.ru/mikrotik/json-parser-script)
Last edited by Chupakabra303 on Wed Jun 27, 2018 4:50 pm, edited 2 times in total.
thantoldo
Thu Apr 19, 2018 11:23 am
Can you please raise the fetch variable 65535 character limit (double it or remove it completely), so that the error case "max line length 65535 exceeded!" is resolved?
It happens both with GET and POST.
As routerOS is more and more involved in the big data domain, it is imperative that such limitations are removed.
Also, is there a hardcoded fetch timeout? Can it be exposed as a fetch parameter?
shdwmstff
Fri Apr 20, 2018 10:57 pm
SNMP-GET
I would like to poll external devices and have based on the results change routes, enable/disable interfaces.
It would be a nice feature.
pe1chl
Sat Apr 21, 2018 1:45 am
SNMP-GET
I have been thinking about polling SNR/CCQ of radio links and tuning BGP parameters using the results.
First from some external Linux system, when it is workable it would be nice when the router itself could do it.
telepro
Mon May 14, 2018 4:03 am
+1 for SHA1 and SHA256 hash function
better debugging environment
indication of the line number instead of no response when attempting to start a script with an syntax error
output of line number when importing a script encounters a run-time failure
doneware
Trainer
Trainer
Thu Jul 12, 2018 7:38 pm
JSON encoder
regexp (PCRE) string manipulation
#TR0359
Mantrid
Fri Jul 27, 2018 3:53 am
function for in RAM memory save\load\parse any big raw data.
"tool fetch", any backup and e.t.c scripts need save data to NAND ... NAND have write limit or small size
Mikrotik need any power functions for manipulate big data in available RAM.
eworm
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 4:01 pm
Would be nice the see the bitwise operator for IPv6 addresses...
[admin@MikroTik] > :put (192.168.88.10 & 255.255.0.0)
192.168.0.0
[admin@MikroTik] > :put (2003:cf:2f1e:5c00:d250:99ff:fec0:d180 & ffff:ffff:ffff:ff00::)
Script Error: cannot compute bitwise "and" of internal number and internal number
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
mrz
Fri Aug 24, 2018 4:34 pm
bitwise operator works, whats missing is :toipv6
eworm
Forum Veteran
Forum Veteran
Fri Aug 24, 2018 5:25 pm
Missing from being implemented or missing in my command?
:put ([:toip6 2003:cf:2f1e:5c00:d250:99ff:fec0:d180 ] & [:toip6 ffff:ffff:ffff:ff00::])
... does not give an error, but does not give output neither.
I mailed support and they told me "to be aware of the issue, perhaps it will be fixed in the upcoming versions" (see Ticket#2018061222006824).
eworm
Forum Veteran
Forum Veteran
Tue Aug 28, 2018 1:17 pm
[admin@MikroTik] > :put ([:toip6 2003:cf:2f1e:5c00:d250:99ff:fec0:d180 ] & [:toip6 ffff:ffff:ffff:ff00::])
mrz, can you give advise?
BTW, this looks borked, no?
:put [:typeof [:toip6 ffff::/64]]
nil
mrz
Tue Aug 28, 2018 2:04 pm
Yes it is not implemented.
rendezz
Mon Sep 17, 2018 11:09 am
url_encode();
+1 to this, my implementation is limited and awful
Home of the Badjr, the cloud-managed business network router built on Mikrotik http://baselinecloud.com/badjr
Usermikrotik
Thu Sep 27, 2018 12:10 pm
simulate a runtime command and send it to a running command in a script like in these commands
howdey57
Mon Oct 08, 2018 11:23 am
I'd like to have a debug function that helped with basic syntax. When writing code I spend most of my time getting the basics in place. I write my logic then comment most of it out then uncomment line by line to make sure each line is working. With ros code, if it doesn't work, you get nothing to say where the error is
Also,
- log dates in YYYYMMDD HHMMSS format.
- log dates that work around midnight when not in GMT.
- Ability to add items to end of arrays
Charles
Chupaka
Mon Oct 08, 2018 11:35 am
You may paste the script into Terminal after "{" - that will prevent it from running line by line. Then "}" and Enter to execute.
Looks like "+" works just fine:
	:local a {1;2;3};
	:set a ($a + 5);
	:foreach v in=$a do={
		:put $v
Russian-speaking forum: https://forum.mikrotik.by/. Welcome!
For every complex problem, there is a solution that is simple, neat, and wrong.
MikroTik. Your life. Your routing.
howdey57
Mon Oct 08, 2018 11:48 am
Thanks. I'll try those. Are they mentioned in the wiki?
Any thoughts on the dates?
Chupaka
Mon Oct 08, 2018 11:51 am
Not sure :)
I didn't get what's wrong with dates, sorry
eworm
Forum Veteran
Forum Veteran
Mon Oct 08, 2018 11:55 am
No, the documentation says using a comma is the correct way:
:set a ($a, 5);
https://wiki.mikrotik.com/wiki/Manual:S ... _Operators
howdey57
Mon Oct 08, 2018 5:06 pm
Thanks. Commas it will be!
The date challenge is twofold:
1. Dates in the log file are not consistent. The date is excluded from entries for today and the year is missed out for entries this year. Ideally there would be a switch to set all log date/times to YYYYMMDDHHMMSS format. Machine readable and sortable.
2. If the router is set to anything else apart from GMT (ie there is a time offset), the log entries date/times go mad around midnight (GMT). Look at your log files when time is 00.00 GMT. I can only think it is a bug in ros. I'm on 6.43.2
Charles
Chupaka
Mon Oct 08, 2018 5:38 pm
Well, I believe log format has nothing to do with built-in scripting functions...
About 00:00 bug (unfortunately, I don't have a log at 00:00, so I don't know what are you talking about) - have you contacted support@mikrotik.com?
howdey57
Mon Oct 08, 2018 5:46 pm
Chupaka
You are correct about log entries not directly being about functions but the flip side is that you need lots of other functions to be built to manipulate the inconsistent log date formats.
I'll try support@.
Charles
plisken
Wed Oct 17, 2018 4:47 pm
Secure DNS implementation would be welcome in the future
Chupaka
Thu Oct 18, 2018 11:51 am
What scripting functions do you mean?..
plisken
Thu Oct 18, 2018 12:23 pm
Hallo Chupaka, something like that.
In the same way the SSL turns HTTP web traffic into HTTPS encrypted Web traffic, DNSCrypt turns regular DNS traffic into encrypted DNS traffic that is secure from eavesdropping and man-in-the-middle attacks.
Grt
Chupaka
Thu Oct 18, 2018 12:29 pm
You mean, some function like ":resolve", but using DNSCrypt protocol?
plisken
Thu Oct 18, 2018 12:30 pm
Yes indeed that's what i mean Chupaka.
mrz
Thu Oct 18, 2018 1:13 pm
Completely unrelated to original topic.
pe1chl
Thu Oct 18, 2018 4:11 pm
What is the progress on the original topic? Has it been decided if this is going to happen, when, and what functions?
plisken
Tue Apr 23, 2019 5:24 pm
What topic is unrelated?
doush
Long time Member
Long time Member
Tue May 14, 2019 11:44 am
API responses are not Django Framework Web Template friendly for example Django cannot parse '-' .
For example api(cmd='/ip/dhcp-server/lease/print') returns the following
({'.id': '*213', 'address': '192.168.10.57', 'mac-address': 'F5:DE:F1:24:DC:20', 'client-id': '1:f0:de:f1:23:dc:2a',})
.id cannot be a key starts with a dot.
mac-address cannot be a key because it has '-'
same for client-id
We need a function to replace the '-' with '_' underscore and remove the dots as well to make it work with modern web frameworks.
mrz
Tue May 14, 2019 11:56 am
You can replace any symbol in your application.
eworm
Forum Veteran
Forum Veteran
Wed Jul 24, 2019 12:21 am
Any news on this topic? We have not heard anything in a long time.
plisken
Thu Jul 25, 2019 4:46 pm
With firewall address-list with blocked ip automatically add dns resolve with name.
Would be a nice asset
mrz
Thu Jul 25, 2019 5:00 pm
and how exactly it is related to scripting functions?
cdiedrich
Forum Veteran
Forum Veteran
Thu Jul 25, 2019 5:58 pm
[removed b/c off-topic]
Additionally to all the mentioned functions, I'd consider a basic set of IP calculations very helpful.
-Chris
Christopher Diedrich
MTCNA, MTCUME, MTCWE
Basel, Switzerland
Bremen, Germany
There are 10 types of people: Those who understand binary and those who don't.
There are two types of people: Those who can extrapolate from incomplete data
pe1chl
Thu Jul 25, 2019 7:33 pm
I'd love to see the terminal object-oriented.
Please stop the off-topic messages, and please delete them if they are yours.
(I will delete this when that happens)
cdiedrich
Forum Veteran
Forum Veteran
Fri Jul 26, 2019 12:21 pm
After re-reading my post I have to fully agree. Edited.
Thanks,
-Chris
Basel, Switzerland
Bremen, Germany
jondavy
Wed Aug 14, 2019 1:12 am
the ability to scan ssid via station script, thus automating and choosing the signal-based ssid, ccq in a simple way with one function
SiB
Mon Aug 26, 2019 4:55 pm
Manipulate DATE and TIME.
With Time we can do +-wdhms until not cross >24h. After that we receive the prefix like 1w3d.
/put ("13:14:15" +1w2d23h59m59s)
1w3d13:14:14
With DATE "jan/01/2019" we cannot do any of this operation like +1d. My workaround is script to Crossing Midnight by using ROS internal scheduler and own rules. Example
This should be Built in ROS function and some part of it is implemented in scheduler. This works with LeapYear too.
/system scheduler add name=SiBTemp on-event={nothing } start-date=feb/31/2019;
put [/system scheduler get [find name=SiBTemp] start-date]
mar/03/2019
MTCNA + MTCRE + MTCINE | ~600 users at ~150 RouterBoards in EMEA | Telegram: @SiB_PL | Buy me a caffe
WinBox Tip: F6 works as ALT+TAB | Gliffy.com - free network schematic | prnt.sc - free ScreenShot software
SiB
Sat Aug 31, 2019 8:31 pm
Please let us do
  • CTRL+L, means "clear / cls" - Clear Screen feature from CLI scripting.
  • Put color on text by esc char. Currently it's build-in onto
    interface wireless spectral-history wlan1 duration=2s
    but not published to us.
szalkerous
Tue Sep 24, 2019 8:52 pm
Not sure if already suggested, but JSON support would be absolutely amazing!!!!!
See: JParseFunctions for a kinda hacky (but extremely useful) workaround that really needs to be implemented natively!
My Devices: CCR1009 Primary Router+Firewall / CRS328 main switch / 3x cAP AC / BaseBox 2 (RB912) 2.4Ghz AP / NetBox 5 (RB911G) 5Ghz AP / Handful of RB260GS switches.
mmorelie
Thu Sep 26, 2019 12:02 pm
I agree with everything that has been said before. I also support the proposal made at the beginning of MD5Hash because sometimes the download of RouterOs or configuration file fails.
pe1chl
Wed Oct 02, 2019 3:08 pm
- a set of functions to support accessing another RouterOS device via API
mmorelie
Thu Mar 12, 2020 10:55 am
hi,
possibility to create variables named from object on the routeur like :
:varname [:caps-man remote-cap get $i serial]
so i have a variable named BF090FS8938 (serial number of the router)
/env print
BF090FS8938={foo="bar"; foo; bar}
eworm
Forum Veteran
Forum Veteran
Thu Mar 12, 2020 11:48 am
hi,
/env print
You could put this into an array...
[admin@mt] > :global RemoteCap [ :toarray "" ];
[admin@mt] > :set ($RemoteCap->[ /caps-man remote-cap get $i serial ]) {"foo"="bar"; "bar"="testing..."}
[admin@mt] > :put ($RemoteCap->[ /caps-man remote-cap get $i serial ]->"foo")
bar
[admin@mt] > :put ($RemoteCap->"BF090FS8938"->"bar")
testing...
Does that help?
mmorelie
Thu Mar 12, 2020 12:33 pm
I know but the variable doesn't have the serial number as name, here the variable is RemoteCap.
Sometimes it could be usefull.
ohilton576
Fri Apr 17, 2020 9:35 pm
String comparison would be great!
I am trying to sort my queue by name so I can group similarly named queue items in IP cluster ranges for further processing, but I am getting the dreaded "Script Error: cannot compare if string is less than string"
I can't even convert first character to some kind of number...
:if ([:tonum [:pick $strQueueName 0 1]] < [:tonum [:pick $strQ2CompareWith 0 1]]) do={....}
macsrwe
Forum Veteran
Forum Veteran
Sun Apr 19, 2020 1:01 pm
You can if you name your queues with a first character that is a digit, otherwise you would have to do :find of a collation string. There's no function that returns the raw byte value of an arbitrary element.
pakillo
Sun Jun 07, 2020 11:47 am
Just give us a bash
msatter
Sun Jun 07, 2020 3:21 pm
Replace or remove character(s) in a string.
 global replaceCharacterFunc do={
  while condition=[find $1 $2 0] do={
   set $1 ("$[pick $1 0 ([find $1 $2]) ]".$3."$[pick $1 ([find $1 $2]+1) ([len $1])]")}
  return $1
# Replace a character with an other character
put [$replaceCharacterFunc "Can-t-be-used-as-name-for-variable" "-" "*"]
# Remove unwanted character(s)
put [$replaceCharacterFunc "Can-t-be-used-as-name-for-variable" "-"]
Correct that the first character in the string could also be the one that could be replaced:
Loving my freedom and so, no Twitter, no Facebook/Instagram/WhatsApp, no Apple and no Google/Alphabet, no Amazon/Cloudfront/AWS.
Running:
RouterOS 6.49Beta / Winbox 3.27 64bits
jondavy
Sun Jun 14, 2020 9:20 pm
Abilities with script to scan scan and connect into SSID with best signal when SSID start with criteria example:
This is a very important facility for field installations because the technician will not need to link or the notebook will be expedited or serviced, as is the case with GPON (expedited installation). example:
/interface wireless set [find default-name=wlan1] scan-and-connect = based-best-signal-ssid = [find=IspXSectorY];
Ability of AP to announce for all stations that there will be a nv2-mixed-background-scan-from-all of freq-usage from all stations and AP, review graphic for AP and mix as scan of all based at a time ex: 04:00am and temporarily save the RAM into the AP,
of the month that had to stop or painel for some seconds, we would assimilate a scan more from all clients and that would work even for AC chips Also,
when someone request a scan from or AP, warn them that they have scan and show a graph. example:
/interface wireless set [find default-name=wlan1] set nv2-mixed-background-scan-from-all=enabled nv2-mixed-background-scan-time = 04: 00am
vortex
Mon Jun 15, 2020 12:03 am
Just give us a bash
I prefer scsh.
s3RYjUr9ABp4
Mon Aug 03, 2020 9:21 am
Need.
Lua script.
mike548141
Sun Aug 16, 2020 5:20 am
To me the singularly most important addition would be opening this up to the community so that they could create and share functions safely and easily. So that you can leverage all the developers to contribute to a user extensible library.
pe1chl
Tue Aug 18, 2020 4:18 pm
You can always start such a project or join an existing one, e.g. on github.
Don't expect this from MikroTik, they are not an open-source company!
MtHoodlum
Tue Aug 25, 2020 10:34 pm
THIS
MtHoodlum
Tue Aug 25, 2020 10:43 pm
A websockets client would be extremely useful. We recently built a compiled C websockets client from scratch just including the TLS library. MikroTik would be welcome to include this as a package in future versions of RouterOS.
Mannsean
Fri Aug 28, 2020 1:55 am
Just as said above, i think you have more chances with it on github
MtHoodlum
Sat Sep 12, 2020 7:20 pm
A built-in function that broke up files and variables into 4096 byte chunks would be extremely useful.
pe1chl
Sat Sep 12, 2020 11:47 pm
I think the scripting language should be extended with a file open/read/write/close construct where you can open a file (a handle is returned), then read or write it in a loop either line-by-line or as fixed-size blocks (up to 4096 bytes), and then close it when finished. The total size of the file would be arbitrary (as long as it fits on the storage).
This would be similar to the C functions fopen, fgets, fputs, fread, fwrite, fclose.
This would allow reading and processing long lists of data like blacklists etc.
Chupaka
Thu Sep 17, 2020 1:27 am
Even kind of ":foreach line in=[/file xxx get-lines] do={$process $line}" should be enough, I believe...
pe1chl
Thu Sep 17, 2020 11:10 am
Ok, that would likely read the entire fire beforehand and store it into an array in memory, but indeed for many purposes (and with today's typical RAM size) that would already be very good!
Of course it would be nice when there also was some way to write-out such an array to a file (1 array element per line, total array larger than 4K).
msatter
Thu Sep 17, 2020 12:03 pm
What if you use multiple array's in the foreach? Till now I read/stores up to 64KB files using one array.
When one array is full then switch to the next one.
Running:
pe1chl
Thu Sep 17, 2020 12:27 pm
Oh, I did not know that there was a 64kB limit on arrays.
When that is the case, forget about that method and just do the open/read/write/close. It has no such limits, it can loop to read all lines and process them without storage limit issues.
(reading and processing lines one by one does not necessarily mean they have to be permanently stored somewhere in memory, maybe it is just to add them to an address list or similar purposes)
msatter
Thu Sep 17, 2020 12:48 pm
This I am using to read up to 64KB from a file. Sadly always the first up to 64KB from a file.
 :local result [/tool fetch url=$url as-value output=user]; :if ($result->"downloaded" < 64) do={ :local data ($result->"data")
If a file is bigger then that, then the result is not transferred to the array due to the data is incomplete. This could work also for bigger files if the webserver supports resume and Mikrotik implements a new starting point for downloading the file using the resume option.
Quick-and-dirty:
Resume available: current read data is different from the previous data
No resume available: current read data is the same as the previous data
Edit: changed the check on the size of the downloaded file: :if ($result->"downloaded" < 64)
Running:
pe1chl
Thu Sep 17, 2020 1:56 pm
Does that already split the data on line boundaries into elements of the array? In that case it is equivalent to what Chupaka suggested to be added.
However, I prefer solutions that do not have such small arbitrary limits.
E.g. when I would like to download a file with lines with addresses or subnets, to add them to an address list, I would like to be able to process a file no matter if it is 10K 100K or 1M.
The open/read/close method does not have any inherent size limits, you can read the lines one by one in a loop, parse them to extract the interesting data, check if the item already is in the address list, if not, add it, and loop until all lines are read.
No need to fiddle with "if larger than this then that".
(I also use the loading of address lists via DNS but it has silly limits as well, you cannot load like 10000 items this way. and it also does not support subnets)
Chupaka
Thu Sep 17, 2020 3:31 pm
I remember they promised a possibility to use routing filters to add/fetch routes to/from address lists in v7. That would probably be better solution for this case...
pe1chl
Thu Sep 17, 2020 4:08 pm
For this to be of any use, first two changes have to be made:
- address list from DNS should allow subnets, via a TXT record containing CIDR subnet notation (in addition to current A and AAAA record support)
- address list from DNS should have no unreasonable size limits, i.e. when I can "dig" the DNS name from a Linux shell, it should also be able to load that into an address list.
e.g.: dig -t A (some domain name) | wc -l
3546
cannot currently load this into an address list...
Chupaka
Thu Sep 17, 2020 8:18 pm
Oh, I forgot to mention BGP... I mean, with that routing filter one may distribute address list (with subnets and whistles) via BGP, not using files...
pe1chl
Thu Sep 17, 2020 9:37 pm
Ok, I thought you meant to use address lists as part of routing filters (the other way around) and then distribute those lists via DNS...
SimonThomasen
Sun Oct 25, 2020 8:40 pm
read+Write 1 line of text, append to text file, to not have to read/write the whole file
Larsa
Tue Oct 27, 2020 6:43 pm
Catch error messages
Larsa
Tue Oct 27, 2020 6:45 pm
micro python :)
Chupaka
Tue Oct 27, 2020 9:54 pm
You mean, in here? https://wiki.mikrotik.com/wiki/Manual:S ... ime_errors
Larsa
Tue Oct 27, 2020 11:16 pm
Que? That just catches "an" error. There is no way to get the actual error message ie type of error.
Users browsing this forum: No registered users and 26 guests
