mmorelie
Array modification
Fri Apr 06, 2018 3:34 pm
I try to create a script that get information from the configuration of the router or from some commands and store the result in an array.
I have declare some pppoe-client links and want to know the status of each one and save it in different array, one per pppoe-client link.
:global LD1 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LM1 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LDV1 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LV2 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LM2 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LDV2 {user="" ; interface="ether1"; operstatus="" ; admstatus=""; upcounter=0}
:global LOGIN {"LD1"; "LM1"; "LDV1"; "LV2"; "LM2"; "LDV2"}
I have create a loop to parse every pppoe-cleint link :
:foreach i in $LOGIN do={:interface pppoe-client monitor $i once do={:set ($i->"operstatus") $status}}
But the result is not what i want :
 environment print
LD1={admstatus=""; interface="ether1"; operstatus=""; upcounter=1; user=""}
LDV1={admstatus=""; interface="ether1"; operstatus=""; upcounter=0; user=""}
LDV2={admstatus=""; interface="ether1"; operstatus=""; upcounter=0; user=""}
LM1={admstatus=""; interface="ether1"; operstatus=""; upcounter=0; user=""}
LM2={admstatus=""; interface="ether1"; operstatus=""; upcounter=0; user=""}
LOGIN={"LD1"; "LM1"; "LDV1"; "LV2"; "LM2"; "LDV2"}
LV2={admstatus=""; interface="ether1"; operstatus=""; upcounter=0; user=""}
what is wrong ?
pe1chl
Re: Array modification
Fri Apr 06, 2018 4:28 pm
Impossible to know when it is not clear what would be the expected result...
However, I feel with you. Debugging RouterOS scripting is extremely tricky and it often behaves different from what you expect.
What I learned the hard way is to always break up things in small statements. The expression evaluator is very primitive.
However, I don't know how to apply that to your problem.
mmorelie
Fri Apr 06, 2018 4:48 pm
the result as to be for exemple :
LD1={admstatus=""; interface="ether1"; operstatus="connected"; upcounter=1; user=""}
pe1chl
Fri Apr 06, 2018 4:57 pm
why?
the result is set to $status. is $status set to "connected" outside of your example?
mmorelie
Fri Apr 06, 2018 5:03 pm
no $status is not fixed, it's read from the command :
it can be connected or disconnected or something else
pe1chl
Fri Apr 06, 2018 5:28 pm
But where is that transferred to $status? I don't see that anywhere.
I think you need to:
:set $status [:interface pppoe....]
and then you can set the array variable to $status.
mmorelie
Fri Apr 06, 2018 6:18 pm
it's done with this line
when you do :interface pppoe-client monitor LD1 once do={:set (LD1->"operstatus") $status
the actual status is put in the array LD1, at operstatus variable value.
I want this for each one of my value in array LOGIN
pe1chl
Fri Apr 06, 2018 7:43 pm
As I wrote earlier, the expression evaluator is very primitive.
Separate what you want to do in some steps.
First put the status in a variable, then put the variable value in the array.
But I don't understand this "monitor" command and the relation to the $status variable, so I could be wrong.
Users browsing this forum: Majestic-12 [Bot] and 15 guests
