when trying to use the PEAR2 PHP API I find the following problem. Commands that should work such as:
Code: Select all
$util->setMenu('/ip firewall filter');
$util->disable();
Code: Select all
PEAR2\Net\RouterOS\RouterErrorException: Error when disabling items in /var/www/html/pru/PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Net/RouterOS/Util.php:634 Stack trace: #0 /var/www/html/pru/ros_4_fw.php(73): PEAR2\Net\RouterOS\Util->disable() #1 {main} Response collection: Array ( [0] => PEAR2\Net\RouterOS\Response Object ( [unrecognizedWords:protected] => Array ( ) [_type:PEAR2\Net\RouterOS\Response:private] => !trap [attributes:protected] => Array ( [message] => failure: cannot change builtin ) [_tag:PEAR2\Net\RouterOS\Message:private] => ) [1] => PEAR2\Net\RouterOS\Response Object ( [unrecognizedWords:protected] => Array ( ) [_type:PEAR2\Net\RouterOS\Response:private] => !done [attributes:protected] => Array ( ) [_tag:PEAR2\Net\RouterOS\Message:private] => ) )
Code: Select all
$util->disable(1);
Is there any way to skip that dummy rule when using disable(), enable() or find() ?
Thanks in advance.
Gerardo.
