e066377
Translate Command Line Command to C#
Tue May 15, 2018 1:51 pm
I want to change the following command line working command in to C# code, how can i do that?
system logging action set memory memory-lines = 1000
Tried tik4net and mikrotik low level api:
using (ITikConnection connection = ConnectionFactory.CreateConnection(TikConnectionType.Api))
	connection.Open(RouterIpAddress, RouterUserName, RouterPassword);
	var command = connection.CreateCommandAndParameters("/system/logging/action/set", "/memory/memory-lines", "1000");
	command.ExecuteNonQuery();
MK mikrotik = new MK(RouterIpAddress);
if (mikrotik.Login(RouterUserName, RouterPassword))
	mikrotik.Send("/system/logging/action/set");
	mikrotik.Send("/memory/memory-lines=1000", true);
mikrotik.Close();
Neither works.
What am i doing wrong?
nescafe2002
Long time Member
Long time Member
Re: Translate Command Line Command to C#  [SOLVED]
Tue May 15, 2018 3:51 pm
You can use the following C# snippet:
void Main()
  using (var conn = ConnectionFactory.CreateConnection(TikConnectionType.Api))
    var actions = conn.LoadAll<LoggingAction>();
    //actions.Dump();
    var memoryAction = conn.LoadSingle<LoggingAction>(conn.CreateParameter("name", "memory"));
    //memoryAction.Dump();
    memoryAction.Lines = 100;
    conn.Save(memoryAction);
[TikEntity("/system/logging/action")]
public class LoggingAction
  [TikProperty(".id")]
  public string Id { get; private set; }
  [TikProperty("name")]
  public string Name { get; set; }
  [TikProperty("memory-lines")]
  public int Lines { get; set; }
e066377
Tue May 15, 2018 5:00 pm
Thanks nescafe2002, it works :)
Users browsing this forum: No registered users and 22 guests
