Halfeez92
VPN connected script
Tue May 29, 2018 6:34 am
Hi, I want to create a script to notify me if any of the openvpn user is connected and disconnected through telegram api. I have already have the api code but I dont know how to create a code to get information if the user is connected or disconnect. Below is the telegram api code that I have. Only the part to get whether the vpn user is connected or disconnected I dont have. Need help from mikrotik coders out there, many thanks.
# ChatID from telegram that is going to receive reports
:local chat "telegram id";
# API code from Telegram BOT
:local bot "telegram api code";
# Defining message
:local initel "https://api.telegram.org/bot";
:local endtel "&text=";
:local newline "%0D%0A";
:local who "$[/system identity get name]";
:local datetime "$[/system clock get date] $[/system clock get time]";
:local message "User din (Haziruddin) is connected to VPN";
:local messagefinal " $who REPORT$newline $newline $message $newline $newline log date: $datetime \
$newline $newline";
/tool fetch url="$initel$bot/sendMessage\?chat_id=$chat$endtel$messagefinal" keep-result=no;
dasiu
Trainer
Trainer
Re: VPN connected script
Mon Jun 04, 2018 1:53 pm
In PPP profile you have "on-up" and "on-down" scripts. Cannot you use 2 different scripts? :)
Halfeez92
Fri Jun 08, 2018 10:21 am
I am aware of that, but to do that I have to create multiple profiles for each user instead of assigning them to multiple users. If there are any flexible solution, let me know.
dasiu
Trainer
Trainer
Fri Jun 08, 2018 10:30 am
You have 2 options:
1. Create 2 scripts (on-up and on-down) for each user separately
2. Read The ....... Manual :)
on-up (script; Default: ) Execute script on user login-event. These are available variables that are accessible for the event script:
user
local-address
remote-address
caller-id
called-id
interface
on-down (script; Default: ) Execute script on user logging off. See on-up for more details
So - inside the script executed "on-up" you just use the $user variable without declaring it (with :local or :global) before. Your script will know that $user is connected of $user is disconnected. 2 scripts is enough then :).
Users browsing this forum: No registered users and 14 guests
