gotsprings
Forum Veteran
Forum Veteran
Day of the Week for a variable
Thu Jun 21, 2018 5:00 pm
The router clearly knows what day of the week it is when you have rules like.
add action=accept chain=input dst-port=8535 protocol=tcp time=\
    0s-1d,mon,tue,wed,thu,fri
Is the day of the week somewhere that I can pick it and use it?
(For use in my wifi schedule.)
I can use firewall rules to drop the traffic when it is supposed to be off using something like...
add action=accept chain=forward src-address-list=JoeOffice time=\
    9h-17h,mon,tue,wed,thu,fri
That way... people still see the SSID. I would like to disable the SSID after hours.
Command would be...
/caps-man actual-interface-configuration disable cap3,cap6
I have a time range test script... now I need the day.
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
dasiu
Trainer
Trainer
Re: Day of the Week for a variable  [SOLVED]
Thu Jun 21, 2018 6:22 pm
1. Unfortunately, MikroTik doesn't "show" the day anywhere.
2. Other people may already think about it. For example here:
https://wiki.mikrotik.com/wiki/Script_t ... f_the_week
gotsprings
Forum Veteran
Forum Veteran
Thu Jun 21, 2018 7:02 pm
Yikes... I saw that before... was hoping that was not the case anymore as that was from a long time ago.
Thanks dasiu
Mark Twain
Users browsing this forum: MSN [Bot] and 9 guests
