MUM Europe 2020
yo1frenchtoast
Function 'import' don't work with variables
Mon Jun 25, 2018 2:37 pm
I have an issue with the function 'import', it canno't take variables as arguments :
[ansible@que-1-hap] > foreach lib in=[/file find name~".lib.rsc"] do={ put [/file get $lib name] }
convertCase.lib.rsc
diffDate.lib.rsc
getUserContact.lib.rsc
netwatchAction.lib.rsc
sendSms.lib.rsc
sendTelegram.lib.rsc
[ansible@que-1-hap] > foreach lib in=[/file find name~".lib.rsc"] do={ put [/file get $lib name]; import $lib }
convertCase.lib.rsc
cannot open import file, 		    file does not exist
[ansible@que-1-hap] > import
convertCase.lib.rsc  diffDate.lib.rsc  getUserContact.lib.rsc  last-export.rsc  netwatchAction.lib.rsc  sendSms.lib.rsc  sendTelegram.lib.rsc  from-line  verbose  file-name
Context : I'm making 'libraires' (global functions), so I made a bash script to deploy them (the 'foreach' line as in the exemple above)
It must be a new feature to develop =)
Have a nice day !
dasiu
Trainer
Trainer
Re: Function 'import' don't work with variables
Tue Jun 26, 2018 1:28 pm
Maybe try...
foreach lib in=[/file find name~".lib.rsc"] do={ :local libname [/file get $lib name]; :put $libname; /import "$libname" }
dasiu
Trainer
Trainer
Tue Jun 26, 2018 1:32 pm
And I think it's normal behaviour, not a bug :).
Your $lib variable is not "string", but a pointer to a file (try :put $lib, instead of :put [/file get $lib name]) :). You can use it in /file menu, but not in /import. You can also do /file print, find the entry number you like, and then remove it with "/file remove 3", for example. But you can't do "/import 3" the same way. That's why you need to get full name and use it with /import, that was the problem you had :).
yo1frenchtoast
Wed Jun 27, 2018 2:59 pm
Yes thank you =)
I don't know how I could have missed it... Maybe some sleep could have helped me
Thank you a lot again !
Users browsing this forum: No registered users and 6 guests
