SergeS
How to read file content using API?
Fri Jul 13, 2018 12:43 am
I have some application, running Mikrotik API commands to export configuration to the .rsc file and save it as a file on the computer.
I have all steps done, valid .rsc file is created, but i cannot get file content to the computer. It is strange, because i have remembered this specific command was working around two years ago.
I was using command:
/file/print
=.proplist=contents
?name=filename.rsc
Command
/file/print
=from=%s.rsc
=detail=
is also not working...
How to get file content using API?
I see many people asking the same question but i did not see working suggestion...
mrz
Re: How to read file content using API?
Fri Jul 13, 2018 12:28 pm
You will not get file content if file size is larger than 4KB.
SergeS
Fri Jul 13, 2018 6:02 pm
But it was definitely working for larger files, i have tried with export file (.rsc)...
Ok, how can I get file content if size is smaller than 4KB?
mrz
Fri Jul 13, 2018 6:34 pm
<<< /file/get
<<< =.id=*D034A
<<< =.proplist=contents
SergeS
Fri Jul 13, 2018 10:54 pm
/file/get
=.id=*D034A
=.proplist=contents
Ok, this one is working (for small files), thank you.
The way how i did it before:
/file/print
=.proplist=contents
?name=filename.ext
is also working (only for small files).
Still question is how to get >4Kb file content, using API?
mrz
Mon Jul 16, 2018 11:40 am
You can't directly with api. Download file via ftp and then read content locally.
SergeS
Mon Jul 16, 2018 6:18 pm
Bad.. :-(.
Is this bug? or feature? It was working with some older versions of firmware. Are there any hope it may work in future versions?
NetVicious
Mon Jul 22, 2019 9:50 am
More than one year later and the bug it's there yet.
I'm tryting to get the result of the /export command and it seems it's affected by the same limitation of the API.
. . //\/ e t . \/ i c i o u s ..
Users browsing this forum: No registered users and 7 guests
