Ciambot
check ip enabled or not
Fri Jul 13, 2018 1:18 pm
I'd like to check if an ip address is enable or disable through script.
How can I achieve this?
example
- :if (ip address get [find address="x.x.x.x/x"] disabled = yes) do={ ...
- :if (ip address get [find address="x.x.x.x/x"] enabled = yes) do={ ...
Thanks.
dasiu
Trainer
Trainer
Re: check ip enabled or not  [SOLVED]
Fri Jul 13, 2018 3:47 pm
example
Thanks.
Almost great, just work on the brackets:
:if ([/ip address get [find address="x.x.x.x/x"] disabled]) do={
  :put "The address is disabled!";
} else={
  :put "The address is enabled!";
Ciambot
Sat Jul 14, 2018 5:41 pm
It works!
Thanks a lot!
Users browsing this forum: No registered users and 12 guests
