metricmoose
"/tool fetch output=user" Example?
Sat Jul 21, 2018 5:10 am
Mikrotik updated fetch a few months ago with "output=user", which does the following:
Output ::= file | none | user
none -- do not store downloaded data
user -- return up to 63k bytes directly in 'data' variable without storing on disk
file -- store to file
Though the only way I can see the contents of the "data" variable is by running a fetch command directly, I haven't actually been able to grab the contents of the variable in a script and store it in a global variable to use later. I assume it's not fully implemented yet? It's kind of weird that Mikrotik would include an unfinished feature in the current and bugfix releases...
eworm
Re: "/tool fetch output=user" Example?  [SOLVED]
Mon Oct 01, 2018 11:27 pm
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
metricmoose
Wed Oct 03, 2018 1:55 am
Thanks, I guess Mikrotik hadn't finished the feature at the time of my post. I've been messing around with it since the 6.43 update, it's a very powerful option.
BlackVS
Thu Oct 04, 2018 9:29 am
It would be great to allow suppress annoying hard-coded messaging regarding each fetch operation to router's log (i.e. if you have script which fetching each ten seconds - now you get each 10 seconds info message in the log... as result log is full such messages which masking the rest ones). It is the main reason why I stopped to develop Telegram Bot hosted on router (now I'm developng hosted exetrnally bot which have access to router)
Users browsing this forum: No registered users and 8 guests
