MikroX
IP address list export script
Thu Aug 09, 2018 1:53 pm
Dear community,
I'm struggling with creating a script capable to export one of my static firewall Address Lists, named ssh_blacklist, to a .rsc file. I tried doing so with:
/ip firewall address-list print where list="ssh_blacklist" ; export file=ssh_blasklist.rsc
- but it didn't work
/ip firewall address-list find ssh_blacklist ; export file=ssh_blasklist.rsc
- also didn't work
Any ideas?
ronix
Re: IP address list export script
Tue Dec 25, 2018 12:34 pm
Dear
you can use this script to print it to txt file
/ip firewall address-list print file=ssh_blacklist where list=ssh_blacklist
ericksetiawan
Trainer
Trainer
Fri Dec 28, 2018 6:50 am
Try this:
	:local listName "Server"; #change this
	:local fileName "exported.rsc"; #change this
	:local buffer;
	:global filteredList [/ip firewall address-list print as-value where list=$listName && dynamic=no];
	:foreach i in=$filteredList do={
		:set $buffer ($buffer."add list=".$listName." address=".$i->"address"."; ");
	/file print file=$fileName where name="";
	:delay 1s;
	:set $buffer ("/ip firewall address-list; ".$buffer);
	/file set $fileName contents=$buffer;
NOTE : Please note that there is variable size limitation in RouterOS. It will affect your file result.
Jotne
Fri Dec 28, 2018 9:54 am
Why do you like to export it?
If it is to examine the address, you can use send log hits to Syslog.
I do have black list for any trying a blocked port on my router. If you enter this log, router sends a message to my Syslog server (Splunk)
In Splunk I can see all IP address who and when they got in the log.
Here you can see how has tried to access my RDP, but ended are in a block access list.
See my signature for more info.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Users browsing this forum: MSN [Bot] and 17 guests
