marklodge
Get traffic usage via PEAR2 API
Fri Aug 17, 2018 3:34 pm
I wish to see how much bandwidth was used per PPP connection, how would I do this via API, I understand that the options are probably Graphing, SNMP or Netflow.
I just need the simplest way for now. I need to get the usage and create monthly, weekly graphs.
boen_robot
Re: Get traffic usage via PEAR2 API
Sun Aug 26, 2018 12:40 pm
Using a specialized tool that analyzes SNMP and/or Netflow to generate a graph would be most efficient for the router indeed.
If you're OK with sacrificing some of that efficiency for the purposes of customizable implementation, the other way would be to detect a new PPPoE interface appearing (see your other topic), and when a new one appears, issue an "/interface monitor-traffic" command, and collect the results into your DB, from where you can later draw graphs.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
marklodge
Wed Aug 29, 2018 12:06 am
Could you recommend a simple tool please for SNMP or/and for Netflow?
My impression is that I need to setup a Netflow collector server or SNMP collector then pull the data from there to my php script. Am I correct?
Users browsing this forum: No registered users and 9 guests
