Jotne
Finding WAN interface name
Mon Aug 20, 2018 7:25 pm
Hi
I am struggling with RouterOS command line.
I do need to get the interface name of the Wan if.
This commands shows it: ether1-Wan
:put [/ip route check 8.8.8.8]
     status: ok
  interface: ether1-Wan
    nexthop: 92.xxx.xxx.1
This do show all info:
/ip route print
I am thinking of getting the line like this:
:put [ /ip route get [ /ip route find where dst-address=0.0.0.0/0 ]]
and then find the if by using the IP for 0.0.0.0
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
ADahi
Re: Finding WAN interface name
Fri Aug 31, 2018 1:52 am
does this help you?
:put [/ip arp get number=[find where address=[/ip route get number=[find where dst-address="0.0.0.0/0" && active=yes ] gateway]] interface]
ADahi
Fri Aug 31, 2018 1:57 pm
:D Do not struggling with RouterOS command line. :D
:put ([/ip route check 8.8.8.8 as-value once]->"interface")
best regards
Jotne
Fri Aug 31, 2018 2:14 pm
Perfect :)
MikroTik->Splunk
Users browsing this forum: No registered users and 11 guests
