David1234
trying to remove dhcp lease in C#
Wed Aug 29, 2018 11:57 am
Hello ,
I'm tryin to remove dhcp clients by using this all this commands (every time another command....) :
mikrotik.Send("/ip/dhcp-server/lease/remove");
mikrotik.Send("?=server=dhcp1" , true);
mikrotik.Send("?server=dhcp1" , true);
mikrotik.Send("?server=all" , true);
mikrotik.Send("?=server=all" , true);
foreach ?(string m in mikrotik.Read())
in all of them I get no error - "!done"
but it doesn't remove nothing ...
but when I do this :
mikrotik.Send("=.id=*2" , true);
it remove me the *2 client...
why?
what is wrong?
Thanks ,
nescafe2002
Long time Member
Long time Member
Re: trying to remove dhcp lease in C#
Wed Aug 29, 2018 1:13 pm
You are using a query word in a non-print operation, which is not supported.
https://wiki.mikrotik.com/wiki/Manual:API#Queries
print command accepts query words that limit set of returned sentences. This feature is available since RouterOS 3.21.
Alternative is to query first and then remove by id:
var ids = new List<string>();
mikrotik.Send("/ip/dhcp-server/lease/print");
mikrotik.Send("?-server", true);
foreach (var h in mikrotik.Read())
  var startIndex = h.IndexOf(".id=") + 4;
  if (startIndex >= 4)
    var endIndex = h.IndexOf("=", startIndex);
    var id = h.Substring(startIndex, endIndex - startIndex);
    ids.Add(id);
foreach (var id in ids)
  mikrotik.Send("=.id=" + id, true);
  Console.WriteLine(mikrotik.Read());
Note that while Winbox shows server=all, the server is actually undefined for these entries (query word -server).
David1234
Wed Aug 29, 2018 1:33 pm
yes ,
this is what I did for now
saved all the Id and then remove them 1 by 1
Thanks ,
nescafe2002
Long time Member
Long time Member
Wed Aug 29, 2018 2:33 pm
The Tik4Net (strong-typed entity) example:
https://github.com/danikf/tik4net
using tik4net;
using tik4net.Objects;
using tik4net.Objects.Ip.DhcpServer;
var host = "192.168.88.1";
var user = "admin";
var pass = "password";
using (var conn = tik4net.ConnectionFactory.OpenConnection(TikConnectionType.Api, host, user, pass))
  var filter = conn.CreateParameter("-server", "");
  var leases = conn.LoadList<DhcpServerLease>(filter);
  foreach (var lease in leases)
    conn.Delete(lease);
David1234
Thu Aug 30, 2018 10:09 am
all my code is in the mikrotik API and not the Tik4Net
I wnat to start working with this - when I have time
Thanks ,
nescafe2002
Long time Member
Long time Member
Fri Aug 31, 2018 4:35 pm
You have wasted a lot of time already. Just pointing out there are better and quicker solutions.
Assuming you have never installed a NuGet package?
Users browsing this forum: No registered users and 7 guests
