MUM Europe 2020
Roberson
Problema em Login Mikrotik em csharp
Wed Aug 29, 2018 2:37 pm
Good morning, I'm having this error, when trying to login to a mikrotik server. someone has a solution.
thank you
nescafe2002
Long time Member
Long time Member
Re: Problema em Login Mikrotik em csharp
Wed Aug 29, 2018 2:46 pm
The login procedure has changed between 6.43rc19 and 6.43rc29: https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
So either downgrade your device to current, upgrade to >=rc32 or change the Login function to "post-v6.43" as described.
Better, take a look at tik4net which handles API communications for you: https://github.com/danikf/tik4net
Users browsing this forum: aoakeley and 15 guests
