novelty22
e-mail /export script not working since upgrade to 6.40.8
Thu Aug 30, 2018 3:23 pm
In all of our customer routers we have scheduled backup scripts that e-mail an /export every X days.
Since the upgrade to 6.40.8 these are no longer working. I get an error about the filename. Email from the router is working otherwise
Here's the export of the script in question
/system script
add name="Create Export and Email" owner=admin policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive source="/e\
    xport file=Customer-Lastname,Firstname\r\
    \n/tool e-mail send to=\"customer_tik@ourdomain.net\" subject=([/system identity get name] . \" Reload Scripts\") file=Cus\
    tomer-Lastname,Firstname.rsc\r\
    \n"
When i run it from the terminal
/export file=Customer-Lastname,Firstname
/tool e-mail send to="customer_tik@ourdomain.net" subject=([/system identity get name] . " Reload Scripts") file=Customer-Lastname,Firstname.rsc
I get the following
ambiguous value of file, more than one possible value matches input
Even if it's the only file present on the router
With quotes around the filename I get
oad Scripts") file="Customer-Lastname,Firstname.rsc"
input does not match any value of file
If i downgrade back to 6.93.3 it works as expected.
Does anyone else have this issue and what can be done to remedy besides downgrading?
sid5632
Re: e-mail /export script not working since upgrade to 6.40.8
Thu Aug 30, 2018 3:38 pm
Try:
file="\"Customer-Lastname,Firstname.rsc\""
on the "/tool e-mail" command.
novelty22
Thu Aug 30, 2018 3:45 pm
Thanks!
That actually worked
Why would they change this?
I have over 1000 routers that are now no longer backing up and since all of the customer names are different it this will be a challenge to correct.
Is this change maybe reverted in a later version?
sid5632
Thu Aug 30, 2018 3:49 pm
Apparently not. It's still the same on 6.43rc56
The best thing is not to use a comma in the file name in the first place. Use a '-' or a '_' character, or similar.
mrz
Thu Aug 30, 2018 4:05 pm
e-mail tool for quite some time now support multiple file upload (files separated by comma). So it is obvious why your code does not work.
Do not use special synbos in filenames and variable names. Always use quotes for strings and you will not have problems.
Users browsing this forum: No registered users and 11 guests
