ros44
Does find command distinguish small and capital letters
Sat Sep 01, 2018 3:19 pm
Am I doing something wrong with the find command or this is how it works?
Example 1: Here the find command works as expected. It removes an interface from an interface list, based on interface id
/interface list member remove [ find interface=*f00020 ]
* the interface id starts with a small letter)
Example 2. Here find is used in a script and it doesn't work:
[admin@MyRouter] > :global MyVar;
[admin@MyRouter] > :set $MyVar "*f00019";
[admin@MyRouter] > /interface list member remove [ find interface=$MyVar ]
The solution is to change the small letter in the beginning of the interface id to capital one:
[admin@MyRouter] > :set $MyVar "*F00019";
Additionally the IDs all interface list members are starting with capital letter. My question is how it works in example 1 and not in example 2.
[admin@MyRouter] > /interface list member print
Flags: X - disabled, D - dynamic
 #   LIST            INTERFACE
1   CUSTOM_LIST_01           *F00019
2   CUSTOM_LIST_01           *F0001A
3   CUSTOM_LIST_01           *F0001D
4   CUSTOM_LIST_01           *F0001E
Every moment something magical is happening!
ADahi
Re: Does find command distinguish small and capital letters
Sat Sep 01, 2018 3:46 pm
Do not confuse Interface name with Interface id
ros44
Sun Sep 02, 2018 12:12 am
Thank you for taking time to reply to my question.
I am talking about interface id. When used in terminal command find works well no matter if the interface id starts with capital or small letter. When used in a script it requires only capital letters. This is my problem.
ADahi
Mon Sep 03, 2018 11:13 am
my router output
6.40.9 bugfix
 #   LIST        INTERFACE
 0   test        ether3
 1   test        ether4
 2   test        ether5
ros44
Mon Sep 03, 2018 11:44 am
Do you have any ppp interfaces? Can you add manually via winbox an interface to a test list. Then disconnect the interface and show a /interface list member print.
ADahi
Mon Sep 03, 2018 2:04 pm
this mean interface deleted and shown as unknown interface
ADahi
Re: Does find command distinguish small and capital letters  [SOLVED]
Mon Sep 03, 2018 4:55 pm
for delete "unknown" interface from list use
/interface list member remove numbers=[ find where list=test && interface~("^\\*[A-Z]+") ]
ADahi
Tue Sep 04, 2018 6:05 am
or use this instead
ros44
Thu Sep 06, 2018 11:14 am
I feel so lame. I spent hours on debugging a script to add/remove interfaces from a list your last post made me flash for a moment. It could have been so simple. Thank you.
Another way to do it was given to my by the support:
On-up:
:local interfaceName [/interface get $interface name]
/interface list member add interface=$interfaceName list=OPERATORS_IFs
On-down:
delay 1
:local interfaceName [:toid $interface]
/interface list member remove [find interface=$interfaceName]
Users browsing this forum: riyoritsu and 28 guests
