cheloalb
Script to compare RX-Rate?
Tue Sep 04, 2018 3:55 am
Hello everyone!
I am looking for a script that compares the RX-Rate of wlan1 with a specific number and according to that execute another script, does someone help me? I was trying to do it but I can't find the correct parameters.
thousands of thanks
ADahi
Re: Script to compare RX-Rate?
Tue Sep 04, 2018 5:29 am
hi
I can help you, but explain more detail, what you want to do
now you got RX of each station
:do {
:foreach WR in=[/interface wireless registration-table find] do={
 :log info [/interface wireless registration-table get $WR rx-rate]
} on-error={}
now, what next?
cheloalb
Thu Sep 06, 2018 8:46 am
hi
:do {
} on-error={}
now, what next?
Hello! sorry for the delay!
I need the script to compare the RX-RATE with the number 20 and if it is less than 20, execute the Script2 and if it is bigger than 20 do not do anything. it is understood?
Thank you
ADahi
Re: Script to compare RX-Rate?  [SOLVED]
Thu Sep 06, 2018 12:42 pm
punch Accept this answer ✔ :wink:
:do {
 :local R [/interface wireless registration-table get $WR rx-rate];
 :local X [:pick $R 0 [:find $R "M"]]
 :if ($X < "20") do={
 :log warning message=("Found rx-rate=" . $X . "Mbps");
 # your custom script here
}} on-error={:log error message="script failed..."}
cheloalb
Fri Sep 07, 2018 12:47 am
:do {
Can work like this?
:do {
/interface wireless disable 1
/interface wireless enable 1
ADahi
Fri Sep 07, 2018 1:34 am
Can work like this?
:do {
work like that:
:do {
 :do {/interface wireless
  set wlan1 disabled=yes;
  :delay 3s;
  set wlan1 disabled=no;
  } on-error={:log error message="failed..."}
cheloalb
Fri Sep 07, 2018 1:51 am
:do {
Can work like this?
:do {
work like that:
:do {
  :delay 3s;
thank you very much really!!
ADahi
Fri Sep 07, 2018 7:40 am
I know you'd do the same for me. :wink:
Jotne
Fri Sep 07, 2018 8:26 am
No need to quote each others post. Makes it hard to read the thread.
Use Post Reply button at the bottom of the post.
If you need to quote, quote just the part that you need to explain.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
ADahi
Fri Sep 07, 2018 9:39 am
post updated, you're right
cheloalb
Tue Sep 11, 2018 1:55 am
Hi @ADahi You know that I was testing the script, but it is not working, when the RX falls it does run. :(
ADahi
Tue Sep 11, 2018 6:14 am
script will work if found station with rx-rate less than 20 Mbps in wireless registration table
cheloalb
Tue Sep 11, 2018 7:48 pm
Hi, I put this in client cpe, and it does not work, will it take the value in another format? when the cpe falls below 20 it does not restart,
ADahi
Tue Sep 11, 2018 8:20 pm
can you show us the output
cheloalb
Wed Sep 12, 2018 8:04 am
it does not show me anything in the output, it does not indicate error or anything, I paste it in the console and nothing. the equipment is a sxt lite ac
Users browsing this forum: No registered users and 4 guests
