runbound
disable rules by comment  [SOLVED]
Fri Sep 07, 2018 4:41 am
how to disable comment from 1 to 720
i create the script but its not working.
:if ($Comment=1-720) do={
: log info " the user: $User has Temporary Disconnected!"
[ /ppp secret disable $i ]
[ /ppp active remove [find name=$User] ]
ADahi
Re: disable rules by comment
Fri Sep 07, 2018 9:35 am
:do {/ppp secret
 :foreach ix in=[find where (comment>"0" && comment<"721")] do={
  :local sNAME [get $ix name];
  disable $ix;
  :log warning message=("The user: " . $sNAME . " has Temporary Disconnected!");
  :do {/ppp active remove numbers=[find where name=$sNAME]
  } on-error={:log error message=("Disconnecting " . $sNAME . " Failed");}
} on-error={:log error message="script failed..."}
runbound
Fri Sep 07, 2018 6:03 pm
wow thats great but i have problem in the script sir
all of my users where remove after the script is run
ADahi
Fri Sep 07, 2018 6:14 pm
Well, what was your question?
runbound
Fri Sep 07, 2018 6:19 pm
after i run the script sir all my users were disable even there is no comment attached on thier name
ADahi
Fri Sep 07, 2018 6:22 pm
okay wait i will fix it
ADahi
Fri Sep 07, 2018 6:28 pm
updated, check it
runbound
Fri Sep 07, 2018 6:35 pm
thanks u sir ur superb.
last sir. how can i send the name and remote address in firewall address list after the time comment is 0
coming from ppp secret
example
addrss: ip from remote address in ppp secret
comment: name of my user in ppp secret
ADahi
Fri Sep 07, 2018 7:18 pm
try with
Jotne
Fri Sep 07, 2018 8:25 pm
@ADahi
Pleas stop quoting the whole post above you.
Click Post Reply in bottom of post.
Quote only what is needed. (part of post)
You only make it harder to read.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
ADahi
Fri Sep 07, 2018 8:36 pm
@Jotne
are you PHP web designer?
Jotne
Fri Sep 07, 2018 9:57 pm
No I am not
MikroTik->Splunk
runbound
Sat Sep 08, 2018 1:00 am
try with
i tried it sir but the problem is even the comment is not 0 the remote ip is still there.
i need it to show the remote ip in firewall/address list when comment become 0 in ppp/secret.
thanks sir
ADahi
Sat Sep 08, 2018 11:17 am
Updated working
:do {/ppp secret
:local LIST "reminder";
 :foreach ix in=[find where comment="0"] do={
  :if ([/ppp active find where name=$sNAME]!="") do={
   :local IPadd [/ppp active get number=[find where name=$sNAME] address];
   :do {/ip firewall address-list
   add list=$LIST address=$IPadd comment=$sNAME
   } on-error={:log error message=("move address of " . $sNAME . " to address-list failed, maybe exist")}
ADahi
Sat Sep 08, 2018 11:19 am
No I am not
I'm looking for PHP web designer
runbound
Sat Sep 08, 2018 11:29 am
not working sir theres no creation of ip and name in reminder in firewall addres list also i see in logs "script failed"
ADahi
Sat Sep 08, 2018 6:22 pm
@runbound
updated check it again
runbound
Sat Sep 08, 2018 6:47 pm
thank you sir its working now. so helpful. thank you very very very very much
runbound
Sat Sep 08, 2018 7:07 pm
sir one more please
is it possible to send email to my subscriber to inform that they thier subscription is nearly expire because in ppp secret theres no email box there
so possible is write it in a comment like
0 / xxxx@gmail.com
where 0 is my expiration
ADahi
Sat Sep 08, 2018 7:43 pm
why not, explain your project in detail
netflow
Sat Sep 08, 2018 8:37 pm
To answer your first question, why not simply use?
/ppp secret disable [find where comment>="1" and comment<="720"]
runbound
Sun Sep 09, 2018 2:41 am
@runbound
1. @ADahi sir is it possible to update only 1ip in firewall addresslist under the comment name coming from ppp secret from his latest ip address
2. how can i send one time mail to my email and to my client email address
i have to email the client 3 days before the comment becomes 0
:do {/ppp secret
:local LIST "Reminder_Customer";
:foreach ix in=[find where (comment>"-30" && comment<"0")] do={
:do {/tool e-mail send to="xxx@yahoo.com" subject="$sNAME" body="Temporary Disconnected" start-tls=yes}
ADahi
Sun Sep 09, 2018 5:27 am
@runbound
You are going to make things complicated, I recommend you use RADIUS
runbound
Sun Sep 09, 2018 5:52 am
@ADahi
thanks sir how about question1 sir can u help me with that to work
ADahi
Sun Sep 09, 2018 6:44 am
you welcome
:do {/ppp secret
   remove numbers=[find where comment=$sNAME && list=$LIST];
   add list=$LIST address=$IPadd comment=$sNAME;
   } on-error={:log error message=("move address of " . $sNAME . " to address-list failed")}
runbound
Sun Sep 09, 2018 7:04 am
thank u very much for the time you gave to me sir. i so much appreciated. do you have email sir if i have offer for u
ADahi
Sun Sep 09, 2018 7:08 am
I know you'd do the same for me. :wink:
runbound
Sun Sep 09, 2018 1:00 pm
sir @ADahi can you help me again
remember the comment sir from 30 down to 0 and its moving according to my script.
how to add the name TEMP beside those numbers where numbers is moving
i try to add temp in comment but the problem is the numbers in comment not moving anymore
Users browsing this forum: No registered users and 14 guests
