wildbill442
'grep' an output?
Tue Feb 13, 2007 11:36 pm
This is what I'm attempting to do:
/ip arp pr | grep aaa.bbb.ccc
how do I do this in mikrotik syntax? :?
wildbill442
Tue Feb 13, 2007 11:40 pm
Nevermind, found my answer here: http://forum.mikrotik.com//viewtopic.ph ... light=grep
I found it easier to do a "pr file=abc" and ftp the file to a linux box and run cat abc | grep expression
I too second a similar implementation of grep! :)
difan
Re:
Mon Aug 03, 2015 8:59 pm
Me too. MT has to keep in mind that not everybody is a programmer. In stressful support situation, an easier and a more efficient powerful CLI matters more.
patrick7
Re: 'grep' an output?
Mon Aug 03, 2015 10:06 pm
pardim
Re: 'grep' an output?  [SOLVED]
Wed Aug 30, 2017 4:12 am
I've found the way below, I think could help anyone.
e.g:
ip arp print where address=192.168.10.1
Or
ip arp print where mac-address=00:00:00:00:00:01
cmaney
Re:
Fri Sep 01, 2017 6:10 pm
I found it easier to do a "pr file=abc" and ftp the file to a linux box and run cat abc | grep expression)
Just a quick aside, but there is no need to cat the file and pipe it to grep on any Unix/Linux variant I've ever seen. You can simply use: grep expression abc
So: grep 00:aa:15:aa:aa:aa myfilename will work without problems and save you some typing.
pe1chl
Re: Re:
Fri Sep 01, 2017 8:02 pm
Of course it is required in order to earn the "useless use of cat award".
See http://porkmail.org/era/unix/award.html
mike99
Tue Nov 13, 2018 6:59 pm
I was looking for the answer but only find this thread. After looking at the scripting wiki, I found this out.
/ip addr pr where address~"aaa.bbb.ccc"
Users browsing this forum: SiB and 1 guest
