emiliano80
Problem with script
Wed Sep 12, 2018 3:36 pm
I need to delete a list of addresses using index number.
Using the command from the terminal works, example:
/ip firewall address-list remove numbers=6
but
but using it in a script does not work.
possible solutions?
Thanks!
ADahi
Re: Problem with script
Thu Sep 13, 2018 7:47 pm
may be "no such item"
use this command to see what is the output
:put [/ip firewall address-list remove numbers=6 ]
nescafe2002
Long time Member
Long time Member
Thu Sep 13, 2018 8:54 pm
Index numbers are put in buffer after print command. You cannot blindly use these numbers in script.
Use find command instead, based on properties:
/ip firewall address-list remove [ find list=<name> address=<address> ]
Users browsing this forum: No registered users and 11 guests
