ProfLaravel
port tracking in php PEAR2 Api
Mon Sep 17, 2018 3:15 pm
hello ,
is there any way to get a result of this command
/ip firewall connection print where src-address ~":80"
using Php PEAR2 Api i've been searching for a while and what i got that i can't use "~" in my php query
so is there any ideas on query to get the same result using the api ?
thanks
mrz
Re: port tracking in php PEAR2 Api
Mon Sep 17, 2018 4:31 pm
API cannot do this, such selection must be done on your APP side.
boen_robot
Tue Sep 18, 2018 4:58 pm
… And to do it on the app side, you can use preg_match while iterating over all items. You may narrow them down with other allowed criteria if you want (e.g. search for only tcp connections that come from a known interface) to optimize the performance somewhat.
e.g. (without such criteria)
foreach ($util->setMenu('/ip firewall connection')->getAll() as $connection) {
    if (preg_match('/\:80$/', $connection->getProperty('src-address'))) {
        //Connection matches. Deal with it here
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Users browsing this forum: No registered users and 5 guests
