VeeDub
Wait for command to complete?
Tue Sep 18, 2018 5:35 am
I'm sure this question has been asked before, but I can't work out a search that provides relevant results
So I have the following command
:execute {ping 10.0.0.1 interface="bridge / LAN" interval="1000ms" count=30} file=ping.txt
The ping takes time to execute, is there a way that I can monitor for when the ping has completed, or can I only use some arbitrary delay?
I want to read the file once the ping has completed
VW
rendezz
Re: Wait for command to complete?
Wed Sep 19, 2018 11:50 am
You could try
:execute {   ping 10.0.0.1 interface="bridge / LAN" interval="1000ms" count=30; /file print file=pingdone.txt; } file=ping.txt
Then in your later code, or other code where you are waiting, just look for the existence of pingdone.txt which will only be created after the ping is complete. This testing can be done with a :len and a find
Home of the Badjr, the cloud-managed business network router built on Mikrotik http://baselinecloud.com/badjr
VeeDub
Thu Sep 20, 2018 7:15 am
That works great.
Thanks!
Users browsing this forum: No registered users and 1 guest
