CHANDAN576
$ Sign Not Accepting from New Terminal
Fri Sep 21, 2018 3:41 pm
i want to change my client device CPE username and password for misuse. while i am update username ,Like Admin,it is accepted and set , but when i am Set Password with $ , it was not accepting, plz suggest me how can i use $ in password.
mrz
Re: $ Sign Not Accepting from New Terminal
Fri Sep 21, 2018 3:50 pm
It is not recommended to use special characters used by console in anywhere else (including password). But if you really want to use it, then character need to be escaped \$
CHANDAN576
Fri Sep 21, 2018 4:08 pm
Now it is given message"expected end of command (line 1 column 25)"
Escaaped "/" sign error.
CHANDAN576
Fri Sep 21, 2018 4:12 pm
plz suggest me i realy not able to set password with $ command from new terminal.
nescafe2002
Long time Member
Long time Member
Fri Sep 21, 2018 4:16 pm
Use quotes and supply user name after [set] command:
/> user set user1 password="gurga\$2019"
And never use gurga$2019 or derivative as your password again :)
CHANDAN576
Fri Sep 21, 2018 4:54 pm
Now Working Thanks,,,
Thanks a Lot :lol: :lol: :lol:
Users browsing this forum: No registered users and 3 guests
