gotsprings
Forum Veteran
Forum Veteran
Turning off a set of Caps-Man radios
Mon Sep 24, 2018 2:52 pm
Not sure what the mistake here was....
There are 4 Access Points being controlled by caps-man.
/caps-man actual-interface-configuration disable [find configuration.ssid~"Guest"]
Running that turned off the Virtual APs that provided the guest network
However... it also turned off the WAN interface.
The Wan interface is simply ether1-WAN.
Doesn't make sense to me.
RouterOS 6.43.2
"It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
Mark Twain
Users browsing this forum: No registered users and 8 guests
