ekarin
Trainer
Trainer
Script of automatically updating gateway address at routes
Mon Sep 24, 2018 6:01 pm
According to my presentation in the 2018 MUM conference in Thailand, I presented in the topic "Monitoring the Internet Connections of WAN Links
with Only Routing Configuration". https://mum.mikrotik.com/presentations/ ... 743837.pdf
After the conference, I was asked from many people in Thailand on how to automatically update the ISP gateway addresses at routes if the ISP gateway addresses at the WAN interfaces were changed. My presentation showed them how to configure the recursive routes (i.e. routes with the static ISP gateways). As they asked, I realized that some ISPs sometimes change their gateway addresses. I have responded them with a solution to use a script that is able to automatically update the gateway addresses of the routes. I would like to share the following script here. Hopefully it may be useful for others.
In case of PPPoE Client at a WAN Link, the script is as follows:
:local newgw [/ip address get [find interface="pppoe-out1"] network];
:local routegw [/ip route get [find comment="isp1"] gateway ];
:if ($newgw != $routegw) do={
      /ip route set [find comment="isp1"] gateway=$newgw;
Note that you can run it on the On Up event of PPPoE client by putting it in the PPPoE Client's profile.
In case of DHCP Client at a WAN Link, the script is as follows:
:local newgw [ip dhcp-client get [find interface="ether1"] gateway];
Note that you can run it on the system scheduler with an appropriate period of time.
If you want to apply for more than one WAN links, for example, two WAN links (PPPoE Clients), just copy the above script and paste like this.
:local newgw1 [/ip address get [find interface="pppoe-out1"] network];
:local routegw1 [/ip route get [find comment="isp1"] gateway ];
:if ($newgw1 != $routegw1) do={
     /ip route set [find comment="isp1"] gateway=$newgw1;
:local newgw2 [/ip address get [find interface="pppoe-out2"] network];
:local routegw2 [/ip route get [find comment="isp2"] gateway ];
:if ($newgw2 != $routegw2) do={
     /ip route set [find comment="isp2"] gateway=$newgw2;
adminken
Re: Script of automatically updating gateway address at routes
Mon Nov 25, 2019 5:14 am
+1 sir.
Taymaz1987
Tue Sep 01, 2020 10:18 am
Hello my friend
I have internet from an isp.My isp has made settings that only the modem can connect and no bridge mode is used.
For some reason I have to use this isp.I connect modem to Mikrotik router and active dhcp client and always receive ip with CIDR 24 and the gateway is always 100.0.0.1 but it is not reachable.
For example, ip is 100.75.15.121/24, I have to find the gateway manually, which for example goes up to 100.75.15.1
I am not very familiar with the script and my isp is not willing to cooperate.
The only idea I have is to get dhcp client network and add it to 1 and put it in the gateway.
please help me.
FiiMitch
Tue Sep 01, 2020 12:31 pm
I've installed countless Mikrotik routers using VDSL modems for nothing more than modulation and hardware bridging.
Can you specify:
- The make and model of the modem you are using
- How you have configured the bridging
- How the ISP is terminating the connection i.e. PPPoE, IPoE, DHCP
- What Mikrotik device you are using and how it is connected/configured
Also what exactly is meant by:
ip is100.75.15.121/24, I have to find the gateway manually, which for example goes up to 100.75.15.1
Is this what you are currently receiving at the modem level from the ISP? Or what is being handed to your Mikrotik router from the modem?
MTCNA, MTCRE
volkirik
Fri Feb 12, 2021 5:59 pm
i also update srcnat rule.. thanks for posting gateway script
:local EthInterfaceName "ether1"
:local MyComment "terra"
:local newgw [/ip dhcp-client get [/ip dhcp-client find interface="$EthInterfaceName"] gateway];
:local routegw [/ip route get [/ip route find comment="$MyComment"] gateway ];
     /ip route set [/ip route find comment="$MyComment"] gateway=$newgw;
:local "assigned-addr" [/ip dhcp-client  get [/ip dhcp-client  find interface="$EthInterfaceName" ] address]
:if ( [ :len ($"assigned-addr") ] <= 0 ) do=\
  :log info "DHCPc update-srcnat: empty local address"
  :error "DHCPc update-srcnat: empty local address"
} else=\
  :log info "DHCPc update-srcnat: local address for $EthInterfaceName is ($"assigned-addr") (up)"
:local "local-address" [:pick $"assigned-addr" 0 ([:find $"assigned-addr" "/"])]
:local srcnatPPPId
:set srcnatPPPId [ find chain=srcnat action=src-nat out-interface="$EthInterfaceName"]
#check if srcnat exists
:if ( [ :len $srcnatPPPId ] < 1 ) do=\
  /ip firewall nat add action=src-nat chain=srcnat log=yes out-interface="$EthInterfaceName" to-addresses=($"local-address")
  :log info "DHCPc update-srcnat: added srcnat for $EthInterfaceName to ($"local-address")"
} else=\
  :local oldip [/ip firewall nat get [/ip firewall nat find chain=srcnat action=src-nat out-interface="$EthInterfaceName"] to-addresses]
  :if ($"local-address" != $oldip) do={
    /ip firewall nat set [find chain=srcnat action=src-nat out-interface="$EthInterfaceName"] to-addresses=($"local-address")
    :log info "DHCPc update-srcnat: updated srcnat for $EthInterfaceName to ($"local-address")"
cooling
Sat Jul 31, 2021 5:35 am
how to insert two pppoe gateway in one coment , example :
1. out-pppoe1 = gateway {192.168.1.1)
2. out- pppoe2 = gateway (10.10..1.1 ) all gateway dinamic
/ip route ( isp1 )
gateway 192.168.1.1, 10.10.1.1
script
:local routegw1 [/ip route get [find comment="Test"] gateway ];
:local routegw2 [/ip route get [find comment="Test"] gateway ];
:if ($newgw1 != $routegw1),($newgw2 != $routegw2) do={
/ip route set [find comment="Test"] gateway=$newgw1,$newgw2;
but can't work
thanks
volkirik
Sat Jul 31, 2021 11:48 am
https://wiki.mikrotik.com/wiki/Manual:S ... _Operators
:if (($newgw1 != $routegw1) or ($newgw2 != $routegw2)) do={
edit: brackets
rextended
Sun Aug 01, 2021 5:34 am
:if ($newgw1 != $routegw1) or ($newgw2 != $routegw2) do={
Ignoring the other things...
And where do the brackets go?
cooling
Sun Aug 01, 2021 7:38 am
i.m try but can't work
Users browsing this forum: Bing [Bot] and 5 guests
