MUM Europe 2020
pancake
Export data to rsc file
Sun Sep 30, 2018 1:00 pm
Hi I have some troubles with solving this situation. I need to export data from mangle rules (amounts of Bytes and Packets) to a file. I am beginner in scripting i am doing it for first time, so I deeply appreciate every advice. Thank you.
nescafe2002
Long time Member
Long time Member
Re: Export data to rsc file
Sun Sep 30, 2018 2:53 pm
/ip firewall mangle print stats file=stats
It will generate a human readable txt file. If you want to parse these numbers in software, api is a better solution (command /ip/firewall/mangle/print gives you bytes and packets).
Users browsing this forum: No registered users and 10 guests
