ilovepancakes
User agent with fetch tool
Thu Oct 04, 2018 4:58 am
Using the following code to try and update my Google DDNS record with current IP, everything seems to work correctly with communicating with Google but Google returns a "badagent" error since the request needs to send a valid user agent to be accepted by Google. How can I set and/or customize a user agent that is sent with the fetch tools URL request?
# Variables
# Username and password are the long cryptic ones Google Domains provides,
# not your regular Google account ones
:local GoogleDNSUsername "gbML26UKGdjm7Oz1"
:local GoogleDNSPassword "ASmwlKjCAkEywaZC"
:local hostName "test.twinstar5.com"
:local currentIP ""
:local setResults ""
:local previousIP ""
# Script
:set currentIP [/ip cloud get public-address]
:set previousIP [:resolve "$hostName"]
:if ($currentIP != $previousIP) do={
:do {
/tool fetch url="https://$GoogleDNSUsername:$GoogleDNSPassword@domains.google.com/nic/update?hostname=$hostName&myip=$currentIP" mode=https dst-path=GoogleDNS.txt
:set setResults [/file get GoogleDNS.txt contents];
:log info ("GoogleDNS said this: $setResults")
} on-error={
:log error ("GoogleDNS: script failed to set new IP address")
tugsynz
Re: User agent with fetch tool
Thu Jul 18, 2019 11:26 pm
I'm in the same boat and get the same error, did you manage to find a fix for this?
Cheers,
Tugsynz
ilovepancakes
Fri Jul 19, 2019 4:44 pm
Cheers,
Tugsynz
No, unfortunately. I still don't believe there is a way to add or customize a user agent for requests, although I have not tried to do it again on the latest versions of Router OS.
eworm
Long time Member
Long time Member
Sat Jul 20, 2019 12:21 am
/ tool fetch http-header-field="User-Agent: Mozilla/4.0" ...
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
digitik
Wed Nov 27, 2019 1:22 pm
Code: Select all
/tool fetch url="http://example.com/" http-header-field="User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:70.0) Gecko/20100101 Firefox/70.0"
HTTP_USER_AGENT: Mikrotik/6.x Fetch, Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:70.0) Gecko/20100101 Firefox/70.0
Seems to be no chance to replace, just add to "Mikrotik/6.x Fetch"
seedbedUnmoved
Mon Jul 27, 2020 8:22 pm
Sorry to resurrect an old thread but how did you get it to append? I used that exact line and it came back as 'Mikrotik/6.x Fetch' I'm on 6.47.1
Command:
/tool fetch url="http://postman-echo.com/get" http-header-field="User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64; rv:70.0) Gecko/20100101 Firefox/70.0"
Results:
{"args":{},"headers":{"x-forwarded-proto":"http","x-forwarded-port":"80","host":"postman-echo.com","x-amzn-trace-id":"Root=1-5f1f0b8a-fc7505a8e28e38802ca59cf8","user-agent":"Mikrotik/6.x Fetch"},"url":"http://postman-echo.com/get"}
http://postman-echo.com/get just returns what it gets
Users browsing this forum: No registered users and 9 guests
