mikrotiktr
Android Ajax get not working
Tue Oct 09, 2018 1:34 am
i have a software working on PC.
When a ajax get request come from the hotspot login page it creates a user with api.
on the hotspot login page i use an ajax get script to send username to PC sofware.
it is working on PC and Iphone devices but it doesnt work on android. the ajax get request is not success on android.
what is the problem you think?
thank you
boen_robot
Re: Android Ajax get not working
Tue Oct 09, 2018 9:37 am
Hard to tell... You should do some debugging. Both on success and on failure, dump the response (e.g. in an alert), see what it says, and continue investigating possible causes from there.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
Users browsing this forum: No registered users and 17 guests
