MUM Europe 2020
giguard
c# tik4net 3.3.0 How do I convert '/ip ipsec remote-peer remove [ find id="blah" ]' to c#?
Thu Oct 11, 2018 4:13 pm
Searching through the forum I can't seem to find any previous post regarding to the question in the topic.
This is the command I'm running at the terminal
I'm using tik4net 3.3.0 and using it in Visual Studio and writing C# code.
Among many things I've tried, I'm pasting in my last attempt.
            ITikCommand printcmd = connection.CreateCommandAndParameters("/ip/ipsec/remote-peer/remove");
            printcmd.AddParameter("=find", "");
            printcmd.AddParameter("Id", "blah");
I know above code is wrong... (I had to try:P) but you get the picture.
So, how should I go about doing this ?
Thank you,
Daniel
nescafe2002
Long time Member
Long time Member
Re: c# tik4net 3.3.0 How do I convert '/ip ipsec remote-peer remove [ find id="blah" ]' to c#?
Thu Oct 11, 2018 5:03 pm
Only print command supports query words, so split your program into a print with query then iterate the result.
  var cmd = conn.CreateCommandAndParameters("/ip/ipsec/remote-peers/print");
  cmd.AddParameter("id", "blah");
  cmd.AddParameter(".proplist", ".id", TikCommandParameterFormat.NameValue);
  var list = cmd.ExecuteList();
  foreach (var item in list)
    conn.CreateCommandAndParameters("/ip/ipsec/remote-peers/remove", ".id", item.GetId()).ExecuteNonQuery();
Users browsing this forum: No registered users and 27 guests
