Celsius
Script problems for multiple interfaces in global variable
Wed Oct 17, 2018 3:00 am
I've a problem with the following script:
:global VLANBRDNAME "bridge_vlan10"
:global VPNSERVER "PPTP-FIN"
:global ROUTMARK "vpn"
/ip route vrf
add interfaces=$VLANBRDNAME, $VPNSERVER routing-mark=$ROUTMARK
After executing in terminal window, the following error message appear (red mark at comma position between $VLANBRDNAME, $VPNSERVER):
[admin@MikroTik_2] /ip route vrf> add interfaces=$VLANBRDNAME, $VPNSERVER routing-mark=$ROUTMARK
expected end of command (line 1 column 28)
mrz
Re: Script problems for multiple interfaces in global variable
Wed Oct 17, 2018 10:04 am
do not put space after ,
Celsius
Wed Oct 17, 2018 11:03 am
thank you for support. I've remove the space between the variables, because the same error occur:
[admin@MikroTik_2] /ip route vrf> add interfaces=$VLANBRDNAME,$VPNSERVER routing-mark=$ROUTMARK
If i put the values direct in the command it works:
/ip route vrf
add interfaces=bridge_vlan10,PPTP-FIN routing-mark=vpn
The not working part is part of a huge complex script and I need to find a solution. I've no idea to solve the problem.
mrz
Wed Oct 17, 2018 11:41 am
add interfaces="$VLANBRDNAME,$VPNSERVER" routing-mark=$ROUTMARK
Celsius
Re: Script problems for multiple interfaces in global variable  [SOLVED]
Wed Oct 17, 2018 4:27 pm
Thank you, that is the right solution !
Users browsing this forum: No registered users and 8 guests
