man
[SOLVED] BUG (??) /log print where topics=info && message=$message
Tue Oct 23, 2018 5:43 pm
During the executing on the code below, i get all "downloaded" files which are catched at the logger.
  :local message "fetch: file \"flash/home/test.txt\" downloaded";
Output:
  • 17:19:55 info fetch: file "flash/test/tf_1.txt" downloaded
    17:20:02 info fetch: file "flash/test/tf_2.txt" downloaded
    17:20:06 info fetch: file "flash/test2/ico.png" downloaded
But the by path flash/home/test.txt has not been downloaded at all.
man
Re: BUG (??) /log print where topics=info && message=$message
Tue Oct 23, 2018 6:02 pm
Ok i see.
The variable should not be named = message
here:
If we do like that:
/log print  where topics=info && message=$ms
then all works like it should.
strods
Re: [SOLVED] BUG (??) /log print where topics=info && message=$message
Tue Oct 23, 2018 9:31 pm
That is correct. You should never use variable names in RouterOS that are equal with some command or parameter name.
Users browsing this forum: No registered users and 1 guest
