alger
shift array
Thu Nov 01, 2018 12:51 pm
Hello
:global aaa {a=1;b=2;c=3;d=4;be=5}
:foreach k,v in=$aaa do={:put ("$k=$v")}
result is
a=1
b=2
c=3
d=4
e=5
How to shift value in the aray:
a=2
b=3
c=4
d=5
e=6 (new value)
The task is to store only the last 5 values.
Maybe there are other solutions how to do it?
Alexander
ADahi
Re: shift array
Sat Nov 10, 2018 12:48 pm
1st: use local instead of global to prevent issues(local is auto, global is static)
2nd: use "=" inside array index is not needed, use($array->index) better to get or set values
This example may help you to solve your issue
:do {
:local array {1; 2; 3; 4; 5; 6; 7; 8; 9; 10};
 :for i from=0 to=([:len $array]-2) do={
 :set ($array->i) ($array->(i+1));
 :put $array;
} on-error={:log error "ERROR"}
Output will get
2;3;4;5;6;7;8;9;10;10
Users browsing this forum: No registered users and 11 guests
