millenium7
Scripting Array help
Fri Nov 09, 2018 2:10 am
The official help https://wiki.mikrotik.com/wiki/Manual:S ... ith_Arrays is not very helpful when it comes to understanding and using arrays
There needs to be more examples and theory explanation
What i'm trying to do is something like this
:global SetInterfaces {"ether1", "ether2", "ether5"}
:foreach i in=$SetInterfaces do={/interface set [find where name=$i] comment="Mark This Interface"}
I imagine that command should run 3 times, setting each interface specified in the array with the comment of "Mark This Interface" but it doesn't work because when I change the script to this
:foreach i in=$SetInterfaces do={:put $i}
The output is "ether1;ether2;ether5" implying the command runs only once and outputs every array value at the same time
Instead I expect the output should have been
ether1
ether2
ether5
so that it runs 3 times
As a result the first example fails because its only running once and looking for an interface called "ether1;ether2;ether5" instead of running 3 times looking for "ether1" then "ether2" then "ether5"
So my question is how do I achieve the desired result? Keep in mind the length of the array is dynamic, it might only have 3 interfaces now but its not always going to be the case, sometimes only 1 interface, sometimes 20 interfaces or anything in between
Jotne
Re: Scripting Array help
Fri Nov 09, 2018 10:24 am
Try to change , with ;
:global SetInterfaces {"ether1"; "ether2"; "ether5"}
It these are not needed in other places you can use local variable.
:local SetInterfaces {"ether1"; "ether2"; "ether5"}
To test it out wrap all in {} and cut and past it to command line window like this:
PS use code tags on your codes, makes it more easy to read.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
millenium7
Tue Nov 20, 2018 1:11 am
I managed to get this working. Yes need to use ; instead of , in arrays
Also, need to use :for not :foreach. Foreach runs all instances at the same time, for runs one time for each entry separately. Here's a working example that pulls out all values in an array of any length
:global SetInterfaces {"ether1"; "ether2"; "ether5"; "wlan1"}
:for i from=0 to=([:len $SetInterfaces]-1) do={:put [:pick $SetInterfaces $i]}
I know I can use local but global is much easier for troubleshooting. Having to wrap everything in {} means it's not possible to up arrow and simply repeat a command when debugging, plus global will hold the values so I don't have to keep repeating the :local statement. After I change it to a script I can use local variable
Jotne
Tue Nov 20, 2018 9:04 am
If you use Global value, you can later delete them here:
/system script environment
PS please use code tags </> button for your codes.
MikroTik->Splunk
ADahi
Fri Nov 23, 2018 5:05 am
Users browsing this forum: Majestic-12 [Bot] and 40 guests
