surajswifta
DNS CACHES Problems
Mon Nov 12, 2018 1:06 pm
Hello -
as we checking in DNS cache , showing so many DNS caches as -
name: clould.mikrotik.com type: A Data: 81.198.87.240 TTL: 01:31:09
name:mobigifs.xyz type: A Data:172.64.160.4
why its happening and how to stop its
msatter
Re: DNS CACHES Problems
Mon Nov 12, 2018 4:26 pm
Not very special and cloud you can disable if not used under IP-Cloud.
Why do put your public address and port in the Google search machine by showing that here?
Please make those invisible to the gerneral public.
Two RB760iGS (hEX S) in series. One does PPPoE and both do IKEv2.
Running:
RouterOS 6.46Beta / Winbox 3.20 / MikroTik APP 1.3.4
Having an Android device, use https://github.com/M66B/NetGuard/releases (no root required)
Users browsing this forum: No registered users and 10 guests
