kico
system upgrade upgrade-package-source script - password issue
Fri Nov 16, 2018 11:06 pm
I have exactly the same problem as described by user he1ium at Mar 17, 2010
Please mikrotik guys could you add password option at CLI command /system upgrade upgrade-package-source in next RouterOS release?
otherwise it is impossible to make a template .rsc config for multiple routers with auto upgrade option
Ok I have finally given up on this. When executing the /system upgrade upgrade-package-source cmd, it will prompt you for password
[admin@Mikrotik] > /system upgrade upgrade-package-source add address=1.1.1.1 user=mtupdate
password: <- THIS IS THE PART I AM HAVING TROUBLES SCRIPTING BELOW AND THERE IS NO SET PASSWORD OPTION
Here is the issue. There is no cmd to add/edit/anything the password during or after. This makes scripting the password impossible so far. You can only edit the name and the source. If you copy and paste -
p4$$w0RD
into the terminal, this works fine. But put that same code into /system script and it does not work. Anyone have any ideas?
Users browsing this forum: MSN [Bot] and 15 guests
