silderan
API. Listening interfaces and bridges doesn't report deletions
Sun Jan 06, 2019 1:11 pm
Hello.
As subject says, using the commands:
/interface/listen ?dynamic=true?#|
/interface/bridge/listen ?#|
never receive a reply when I delete any dynamic interface (actually, PPPoE clients) or delete bridges.
But, I receive replies when new dynamic interfaces are created or new bridges are created or modified.
It's just an example; I can receive pppoe clients disconnections in /ppp/active/ path. But, what about bridge?
On the other side, users (by /user/listen command), addresses (/ip/address/listen) and prots (/interface/bridge/port/listen) reports everything just fine.
Must I listen bridge in other path?
boen_robot
Re: API. Listening interfaces and bridges doesn't report deletions
Mon Jan 07, 2019 4:17 pm
Try to use
/interface/print
=follow=
?dynamic=true
instead.
Print with "follow" behaves pretty much the same as "listen", as "print" is supposedly the only command that can accept queries.
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
silderan
Mon Jan 07, 2019 6:08 pm
Thank you for your interest.
I did some tests and found this "tips".
  • There are bridge, vlans, etc .dead replies while listening to /interface/. Deeper than this path (like /interface/bridge or /interface/vlan) don't reply.
  • There is not .dead replies from dynamic interfaces while listening to /interface/ Must listen on their specific path (/ppp/active, for example)
  • Using listen or print =follow= behaves identical regarding .dead replies.
  • Queries with listen, actually works!! Is it a new non-notified API feature? (Because in documentation especifically says what you said: queries only works with print/getall command)
  • "OR" and "AND" Query calculation where there is only one query word, doesn't works. It makes sence, because it's intended for 2 values.
Not sure if I'm correct or wrong.
boen_robot
Thu Jan 10, 2019 12:03 pm
Yeah, I've also noticed that "/listen" is effectively an alias for "/print" with "follow-only" argument.
The .dead replies not being consistent across menus is probably a RouterOS bug.
Users browsing this forum: No registered users and 8 guests
