bsayre1958
API to Set DHCP Server Address List
Tue Feb 05, 2019 12:28 am
I have a cli command I am trying to push through the API. The ClI command is
/ip dhcp-server lease set [find host-name="Unit8103Mikrotik"] address-lists="noaccess" I have tested this and it works just fine from the cli. My API looks like this
UnitString = "Unit8103Mikrotik"
mk.Send("ip/dhcp-server/lease/set", False)
mk.Send("=host-name=" & UnitString, False)
mk.Send("=address-lists=" & "noaccess", True)
I am getting the "no such command" in response. I have also pulled the .id and used it as =.id= and the id. I have also reordered the push so the 2 and 3rd lines are reversed. I am using the vb.net sample code to effect this. I have been able to pull the print command using this same host-name without a problem. Any help would be appreciated.
nescafe2002
Long time Member
Long time Member
Re: API to Set DHCP Server Address List
Tue Feb 05, 2019 5:11 pm
The reason you're getting "no such command" is because "ip/dhcp-server/lease/set" is not a valid command.
You're missing the leading "/" => "/ip/dhcp-server/lease/set" is valid :)
Also, you cannot use [ find ] syntax in API. Print with filter to get id, then update by id.
mk.Send("/ip/dhcp-server/lease/print")
mk.Send("=.proplist=.id")
mk.Send("?host-name=" & UnitString, True)
Dim id As String = Nothing
For Each h As String In mk.Read()
    Console.WriteLine(h)
    If h.StartsWith("!re=") Then
        id = h.Substring("!re=.id=".Length)
    End If
Next
If String.IsNullOrEmpty(id) Then Return
mk.Send("/ip/dhcp-server/lease/set")
mk.Send("=.id=" & id)
mk.Send("=address-lists=noaccess", True)
Next
Users browsing this forum: No registered users and 16 guests
