yulley
userman with PHP
Sun Mar 17, 2019 4:47 pm
please help...
i need add user and profile to userman ROS 6.42 with PHP,
for add user success with this script
<?php
use PEAR2\Net\RouterOS;
require_once 'PEAR2/Autoload.php';
$util = new RouterOS\Util(
    $client = new RouterOS\Client('192.168.88.1', 'admin', 'admin', '8728')
$util->setMenu('/tool user-manager user');
$util->add(
    array(
		'customer' => 'admin',
		'disabled' => 'no',
        'username' => 'user1',
		'password' => 'user1',
		'shared-users' => '1',
        'phone' => '+6281345678'
but not success add profile with this
<?php
$util->setMenu('/tool user-manager user create-and-activate-profile');
$util->add(
    array(
		'numbers' => '0',
		'profile' => 'profile1'
boen_robot
Re: userman with PHP  [SOLVED]
Mon Mar 25, 2019 12:12 am
"create-and-activate-profile" is a command, not a menu IIRC.
It's not a normal CRUD command, so you'll have to make a request to give to Client, instead of using Util.
Also, numbers should really contain the username (or otherwise the ID returned by finding the customer/username combo). e.g.
$client->sendSync(
    $util->setMenu('/tool user-manager user')->newRequest(
        'create-and-activate-profile',
        array(
	    'numbers' => 'user1',
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
AdamGweleg
Fri Jul 05, 2019 2:58 pm
$client->sendSync(
        array(
Im using this code but when i run the code I've noted that the router CPU is rising to 30% and each voucher is taking more than 2 minutes.
My router is RB1100AHx4 dude edition v6.43.16
<?php
for ($i = 0;$i < 7500; ){
    set_time_limit(0);
    $lines = file('add.txt');
    foreach ($lines as $line){
if ($i<7500){
        $client = new RouterOS\Client('192.168.1.1', 'admin', '12345')
    $voucher = (int)$line;
    $util->add(
        array(
            'customer'=>'admin',
            'disabled'=>'no',
            'password' => '1234',
            'username' => $voucher,
            'wireless-enc-algo'=>'none',
            'wireless-enc-key'=>'',
            'wireless-psk'=>''
            // 'copy-from' =>'master1d'
     $client->sendSync($util->setMenu('/tool user-manager user')-> newRequest('create-and-activate-profile', [
        'numbers' => $voucher,
        'profile' => '1D'
    $i++;
    echo "numer of vouchers is: ". $i. "<br>";
    echo" VoucherAdded" ." ".$line."<br>";
boen_robot
Sat Jul 06, 2019 4:21 pm
What you're doing is that for every iteration in your loop, you're making a brand new connection, login to the router once again. This is a huge waste of resources.
Move the new RouterOS\Util and new RouterOS\Client outside of the loop, so that you keep using the same connection for all vouchers.
Also, you have two loops, with the "for" one not really serving its purpose. Remove it. You're already making the 7500 check inside the foreach anyway... i.e. only the first 7500 lines in your file would result in vauchers.
AdamGweleg
Sat Jul 06, 2019 6:11 pm
Thank you boen_robot
Today morning I've upgraded my router to the latest stable version because I thought the problem with the router version, and now when I'm trying to connect to the router using API I'm getting a username or password error. 😔
and I'm sure of the credentials are fine because i can log in through inbox.
Any help please??
yulley
Tue Jul 09, 2019 11:38 am
Thank you very much and work with your script
so now i have new problem after added new profile, the billing/time left session will start and pause if any profile before and active in session.
maybe any script just add new profile without activated new profile (new profile will active after previous profile ended).
* i'm sorry my english not good
$client->sendSync(
        array(
onyegbadocu
Mon Jul 15, 2019 12:24 am
I know this an old post. Please i need an assistance on this issue. I am building a database using my php. I want to use a script to add these users from the php database to Userman.
Through google and this forum, i have downloaded Infinitel Hotspot Auto service but to no avail. I have used pearl but to no avail.
see my script below
<?php
require_once 'PEAR2_Net_RouterOS-1.0.0b3.phar';
//$db = mysqli_connect('localhost','root','','students');
$client = new RouterOS\Client('192.168.2.2', 'admin', 'password@1', '8728');
$mysqli = new mysqli('localhost', 'root', '', 'students');
$addRequest = new RouterOS\Request('/tool user-manager user add');
$users = $mysqli->query('SELECT `RegistrationID` AS `username`, `Lastname` AS `password` FROM `user`');
//die(var_dump($users->fetch_object()));
while ($user = $users->fetch_object()) {
$addRequest
->setArgument('name', $user->username)
->setArgument('password', $user->password)
->setArgument('customer', 'admin')
->setArgument('profile', 'staff');
$client($addRequest);
// var_dump($addRequest);
onyegbadocu
Sat Jul 20, 2019 2:33 pm
please help...
<?php
$util->add(
    array(
		'disabled' => 'no',
<?php
$util->add(
    array(
		'numbers' => '0',
I need assistance . i cant load Pear2\Autoloader. php.I get an error that there is a missing directory.
wawananakkaili
Sat Jan 11, 2020 8:22 am
Regards... my First Question... Please Help me...
i was modified every script in this forum for make this working. it was succed in the localhost. but didn't working in the real host... i was user VPS as Userman Server...
Controller :
function __construct(){
parent::__construct();
require_once(APPPATH.'libraries/PEAR2/Autoload.php');
function edit(){
try {
$util = new PEAR2\Net\RouterOS\Util($client = new PEAR2\Net\RouterOS\Client('103.xxx.xxx.xxx', 'user', 'password'));
} catch (Exception $e) {
// redirect when failed
redirect(base_url().'admin/pelanggan/data?alert=gagal_konek_userman');
and there... always failed...
File detail :
host\application\libraries\PEAR2\Autoload
please... help me... and Thanks Before
Last edited by wawananakkaili on Sat Jan 11, 2020 8:33 am, edited 1 time in total.
Users browsing this forum: rjscomms and 16 guests
