plisken
SOLVED Switch on PoE-out when the CPU temperature is too high
Fri Mar 22, 2019 7:00 am
Hello, I would like a script that turns on the PoE-out if the CPU temperature of the router gets too high. Temperature adjustable.
This by script in schedullar.
Does anyone have an idea?
Hoping that someone can help
Jotne
Re: Switch on PoE-out when the CPU temperature is too high
Fri Mar 22, 2019 5:15 pm
This should get you startet.
I do not have PoE interface, so could not test that.
:if ([/system health get temperature] >= 40) do={
/interface ethernet set ether1 poe-out=forced-on
Save this as a script and run it as a schedule job.
To add from cli (10 minute interval and 40 degree as limit)
/system script
add dont-require-permissions=no name=Temperatur-PoE owner=admin policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
    ":if ([/system health get temperature] >= 40) do={\r\
    \n:put \"yes\"\r\
    \n} "
/system scheduler
add interval=10m name=PoE-test on-event=Temperatur-PoE policy=ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
    start-date=mar/22/2019 start-time=15:30:00
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
plisken
Fri Mar 22, 2019 9:52 pm
Hello Jotne, it works like a charm, you are great with scripts.
Thank you verry verry match
Users browsing this forum: No registered users and 4 guests
