krsz
Strange problem with address-list and scripting
Tue Mar 26, 2019 11:23 pm
Hello everyone.
I just try make some script with will be cooperate with VRRP. Nothing special. I configured whole firewall on main router and i exported everything to backup router. Now.. I wont to make changes only on main router. So I wrote script:
if ([:len [/file find name=fw_address.rsc]]>0) do={/file remove fw_address.rsc}
if ([:len [/file find name=fw_filter.rsc]]>0) do={/file remove fw_filter.rsc}
if ([:len [/file find name=fw_layer7-protocol.rsc]]>0) do={/file remove fw_layer7-protocol.rsc}
if ([:len [/file find name=fw_mangle.rsc]]>0) do={/file remove fw_mangle.rsc}
if ([:len [/file find name=fw_nat.rsc]]>0) do={/file remove fw_nat.rsc}
if ([:len [/file find name=fw_service-port.rsc]]>0) do={/file remove fw_service-port.rsc}
/tool fetch mode=ftp address=... port=... src-path=fw_address.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_filter.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_layer7-protocol.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_mangle.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_nat.rsc user=red password=...
/tool fetch mode=ftp address=... port=... src-path=fw_service-port.rsc user=red password=...
   foreach i in=[/ip firewall address-list find ] do={
      /ip firewall address-list remove $i
   import fw_address.rsc
   foreach i in=[/ip firewall filter find ] do={
      /ip firewall filter remove $i
   import fw_filter.rsc
   foreach i in=[/ip firewall layer7-protocol find ] do={
      /ip firewall layer7-protocol remove $i
   import fw_layer7-protocol.rsc
   foreach i in=[/ip firewall mangle find ] do={
      /ip firewall mangle remove $i
   import fw_mangle.rsc
   foreach i in=[/ip firewall nat find ] do={
      /ip firewall nat remove $i
   import fw_nat.rsc
   foreach i in=[/ip firewall service-port find ] do={
      /ip firewall service-port remove $i
   import fw_service-port.rsc
Each part of firewall is exported separately because i was looking for problematic part. And i found it. This script sometime (50/50 changes) can't erase all address-list entry. Script can erase only 20 of those. And exactly first 20 of imported. When i put this part:
nothing will be change.
So i can't understand what is wrong.
Why sometimes whole 31 entry was erased, and why sometime script can erase only 20 and whole script is stopped.
I had the same problem when i exported and imported whole firewall config (/ip firewall export ...)
Can somebody help me :)?
sorry for my bad English.
BlackVS
Re: Strange problem with address-list and scripting
Wed Apr 03, 2019 2:55 pm
One notice - tool fetch asynchoronous i.e. returns immediately but not wait until download finished.
Download is done in background.
As variant you importing files which not yet fully downloaded...
To check this just addd something like:
delay 10s
after last tool fetch
krsz
Wed Jul 31, 2019 1:25 am
After long time i found problem.
I had one dynamic item. I meant with "address" section directed to dns name. I that case You generate two items. One static and one dynamic. When script will delete static one then dynamic one will gone and it is impossible to erase it. So that will make problem with script.
Users browsing this forum: No registered users and 42 guests
