makstex
Howto kill running ppp script?
Mon Apr 15, 2019 4:29 pm
I use the following script to control PPP connections (on-up in ppp profile ):
ping interface=[ / interface get $interface name ] address=($"remote-address") interval=00:00:05
After a PPP interface break, it remains running. Can you please tell me how to kill him?
eworm
Re: Howto kill running ppp script?
Tue Apr 16, 2019 12:37 pm
Try this, replace "ppp-script" with your script name:
/ system script job remove [ find where script="ppp-script" ];
You should consider changing your script...
Manage RouterOS scripts and extend your devices' functionality: RouterOS Scripts
makstex
Thu Apr 18, 2019 7:49 am
This script has no name, it is launched via the ppp profile and they are launched for each PPP connection.
eworm
Thu Apr 18, 2019 8:28 am
Are there any other unique criteria to find your nameless script? If there are non you shout consider putting it into "/ system script".
After all... what's the purpose of this ping?
BTW, ping knows an option "count=" to limit its runtime.
Or you do it in a loop:
:while ([ / interface get $interface running ] = true) do={ :delay 5s; / ping interface=[ / interface get $interface name ] address=($"remote-address") count=1; }
(Edit: fixed typo in script)
makstex
Thu Apr 18, 2019 9:29 am
Purpose: to check the life of the connection and to avoid the forced termination due to idle timeout.
Here is the profile:
/ppp profile add idle-timeout=1m local-address=10.0.0.1 name=ppp-in on-up="ping interface=[ / interface get \$interface name ] address=(\$\"remote-address\") interval=00:00:01" only-one=yes
Great idea with a while loop, thanks, now I'll try.
makstex
Thu Apr 18, 2019 10:29 am
Its worked!
Thank you very much!
eworm
Thu Apr 18, 2019 10:33 am
Fixed the typo in original post. Thanks!
Users browsing this forum: No registered users and 9 guests
