I try to develop a script that is started every 5 seconds to look up connected IPs from a specific interal IP in the firewall/connection list.
e.g. 192.168.88.5 has some active tcp established sessions to 8.8.8.8
then the script should use this command:
Code: Select all
tool fetch url=("https://api.hackertarget.com/reversedns/\?q=8.8.8.8") output=user as-value
Unfortunately I didn't figured it out. Can someone help me?
