franaz
Quick help for short code line
Sun May 19, 2019 8:52 pm
hello to everyone here,
i would like to automatically switch off the wifi after a certain time at night if no user is connected anymore.
I inserted the following code (which btw I found in this forum) in the "on event" field of a schedule task but it's not working:
if ( ([/interface wireless monitor wlan1 as-value once]->"connected-clients")=0 ) do={/interface wireless disable wlan1}
I also tried with "authenticated-clients" and "registered-clients" but no one is doing the job. I guess I have an error in the code , so I would be very thankful if someone who is familiar with the script language could give a look!
(btw: the task to switch on the wifi in the morning is working fine which the following line: /interface wireless enable wlan1)
ADahi
Re: Quick help for short code line
Mon May 20, 2019 4:47 am
:if ( [/interface wireless registration-table print as-value count-only]=0 ) do={/interface wireless disable wlan1} else={}
franaz
Mon May 20, 2019 4:25 pm
unfortunately it's simply not working
I even tried with =1 (while I was the only connected) but no reaction
strangely (as it worked before!) this morning even the activation of the wifi did not work... morning for testing purpose then I set the interval to 1 minute and it worked. for my activation once a day I set the time to 09:00 and the interval to 00:00:00 as it is the 24 hours interval right?)
ADahi
Tue May 21, 2019 2:18 am
interval should be "1d 00:00:00" to work properly
franaz
Tue May 21, 2019 3:09 pm
Thanks for the hint with the 1d .... it works!!
Regarding the other code line there is something fundamentally wrong or at least strange!
It's only doing it's job if I put a ! in front of the =0, so !=0 (or whatever other number), for example:
if ( [(/interface wireless registration-table print as-value count-only)] !=0 ) do={/interface wireless disable wlan1} else={}
this disables the wifi whenever I'm connected or not!
if ( [(/interface wireless registration-table print as-value count-only)] !=1 ) do={/interface wireless disable wlan1} else={}
so with value 1 while I'm connected alone on the wifi it should not disable right? but it does so...
did you make tests on your own? maybe a bug in the software somehow?
thanks again a lot for your time!
ADahi
Wed May 22, 2019 9:26 pm
=0 : mean false or wireless registration table is empty
both are same
other solutions
<=0 : mean less or equal zero
!=0 : mean any number except zero
!=1 : mean any number except one
>0 : mean greater than zero.
etc.
franaz
Wed May 22, 2019 9:34 pm
yes I know but thank you!
how come it's not working with =0 then??
can you test it please on your own mikrotik for a second?
ADahi
Thu May 23, 2019 2:52 am
yes
problem fixed by remove ( ) from script
franaz
Fri May 24, 2019 11:16 pm
sorry I don get it...
a parte the additional code added there, the basic line is just the same... and ( ) still there...?!
franaz
Sun Jun 16, 2019 12:27 am
Anyone else could give me a short help?
Jotne
Sun Jun 16, 2019 12:33 pm
This script does work fin on my hap lite
:if ([/interface get  wlan1 disabled ]=false && [/interface wireless registration-table print as-value count-only]=0) do={
	:log info message="No more clients, shutting down interface"
Schedule it to run every 5m and it should shutdown the interface after max 5 min of last client leaving.
PS I did add a test to see if interface was enabled. No need to shutdown it more than once.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
franaz
Sun Aug 04, 2019 12:52 am
great it works perfectly, thank you so much!!
Users browsing this forum: No registered users and 6 guests
