Martin4
find in log "assigned" or "deassigned" IP by dhcp
Thu Jun 06, 2019 11:00 am
Hi, like subject...
i've already a running script that works fine!
It parse the log to find logged users, but if i add keyword to find "assigned" to, it doesn't find it!
My code was:
:local currentBuf [ :toarray [ /log find where (message~"logged" || message~"login") ] ]
Then i semplify in this code, actually working:
:local currentBuf [ :toarray [ /log find where (message~"user") ] ]
So, i want to add another keyword, to find new logged devices:
:local currentBuf [ :toarray [ /log find where (message~"user" || message~"assigned") ] ]
but it doesn't works! Or better, it works but finds only "user" and not find "assigned".
I try to add topics to, but nothing, it continues to find only "user" keyword:
:local currentBuf [ :toarray [ /log find where (topics~"info" || topics~"dhcp") || (message~"assigned" || "user") ] ]
My scheduler and script have thi permission, and user owner is administrator:
read, write, test
thanks to all.
Jotne
Re: find in log "assigned" or "deassigned" IP by dhcp
Thu Jun 06, 2019 5:53 pm
To debug what is going on, use :put like this:
Se the code ID
:put [ :toarray [ /log find where (message~"logged" || message~"login") ] ]
To see the messages:
/log print where (message~"logged" || message~"login")
This line:
is the same as
(A or B) or (C or D)
And this is the same as
A or B or C or D
So it will give you all lines with any of the A,B,C or D. Not sure if that is your intention.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
Martin4
Thu Jun 06, 2019 7:43 pm
Hi, thanks, now i try...
Yes, i only need OR method.
I want only find A or B or C....
I'm not sure to complain :put command.
In the wiki this is not very well explained.
Jotne
Thu Jun 06, 2019 10:38 pm
From Telnet/SSH Cli, tupe :put and then what do.
Eks print all log line that contains lo
:put [ :toarray [ /log find where message~"lo"]
Your OR work, but you can remove some parentheses.
:local currentBuf [ :toarray [ /log find where (topics~"info" || topics~"dhcp" || message~"assigned" || message~"user") ] ]
PS you missed the message in front of user.
So to test your code, try this from command cline (cli)
:put [ :toarray [ /log find where (topics~"info" || topics~"dhcp" || message~"assigned" || message~"user") ] ]
MikroTik->Splunk
Martin4
Fri Jun 07, 2019 1:45 pm
No....
i try :put from command line (ssh session):
:put [ :toarray [ /log find where (message~"assigned" || message~"user") ] ]
but the result is a series of... i don't know (hex code? other?)
Part of the result:
;*7e4;*7e5;*7e6;*7e7;*7e8;*7e9;*7ea;*7eb;*7ec;*7ed;*7ee;*7ef;*7f0;*7f1;*7f2;*7f3;*7f4;*7f5;*7f6;*7f7;*7f8;*7f9;*7fa;*7fb;*7fc;*7fd;*7fe;*7ff;*800;*801;*802;*803;*804;*805;*806;*807;*808;*809;*80a;*80b;*80c;*80d;*80e;*80f;*810;*811;*812;*813;*814;*815;*816;*817;*818;*819;*81a;*81b;*81c;*81d;*81e;*81f;*820;*821;*822;*823;*824;*825;*826;*827;*828;*829;*82a;*82b;*82c;*82d;*82e;*82f;*830;*831;*832;*833;*834;*835;*836;*837;*838;*839;*83a;*83b;*83c;*83d;*83e;*83f;*840;*841;*842;*843;*844;*845;*846;*847;*848;*849;*84a;*84b;*84c;*84d;*84e;*84f;*850;*851;*852;*853;*854;*855;*856;*857;*858;*859;*85a;*85b;*85c;*85d;*85e;*85f;*860;*861;*862;*863;*864;*865;*866;*867;*868;*869;*86a;*86b;*86c;*86d;*86e;*86f;*870;*871;*872;*873;*874;*875;*876;*877;*878;*879;*87a;*87b;*87c;*87d;*87e;*87f;*880;*881;*882;*883;*884;*885;*886;*887;*888;*889;*88a;*88b;*88c;*88d;*88e;*8.................
In my script i try:
:local currentBuf [ :toarray [ /log find where (message~"assigned" || message~"user") ] ]
it works but find only "user" keyword, nothing "assigned"
Obviously i'm connecting and disonnecting my phone via wifi, and log report correctly assigned and deassigned log.
if i change :local with :put in my script, it doesn't work anymore.
I try to add a 3rd OR, searching "changed" to:
:local currentBuf [ :toarray [ /log find where (message~"deassigned" || message~"user" || message~"changed") ] ]
but, yet, only "user" appear.
EDIT:
I leaved script saved and working like last version:
so... i leave it only "user" detected.........
Now, after about 30 minutes, it detects "changed" keyword to.
Nothing yet about "deassigned" keyword....
Jotne
Fri Jun 07, 2019 7:39 pm
Using find prints the line id that can be used in other part of the script.
Try to replace find with print to get the line.
MikroTik->Splunk
Martin4
Wed Jun 12, 2019 12:52 am
Hi, "print" seems not function...
or maybe i'm not able, but i'm still trying...
Jotne
Wed Jun 12, 2019 6:18 pm
Post line you try to run.
MikroTik->Splunk
Users browsing this forum: No registered users and 6 guests
