teknospr
Script to clear all firewall connections
Wed Jun 19, 2019 8:35 pm
Good day:
I need to create a script that clears all firewall connections if it detects a change in ISP. The problem we have is that when failover occurs, VoIP phones connection hang. This occurs in a place where internet is very unstable.
Jotne
Re: Script to clear all firewall connections
Thu Jun 20, 2019 2:20 pm
This should clear all connection, but not sure how to trigger it:
:foreach i in=[/ip firewall connection find] do={/ip firewall connection remove $i}
Did find a shorter version:
/ip firewall connection remove [find]
This may be used to clear only the sip sections (not tested):
/ip firewall connection remove [find where connection-type=sip]
gotsprings
Mon Jul 01, 2019 7:30 pm
This
I have this exact command in my netwatch when it checks if the Primary ISP's DNS server is there AFTER RECURSIVE ROUTING.
So it CLEARS all connections whether flipping too or away from the Primary ISP.
