eldoncito2019
Script to releases memory
Fri Jun 21, 2019 5:57 pm
Friends, I want to make a script that releases the memory of my RB without needing to restart it, I hope you understand me and can help me. Thank you.!
Jotne
Re: Script to releases memory
Fri Jun 21, 2019 9:19 pm
If there is a command for it, it can be done. I have not seen any.
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
eldoncito2019
Fri Jun 21, 2019 11:00 pm
How would the jotne friend script be?
Jotne
Fri Jun 21, 2019 11:10 pm
Depends on the command.
I do not think there are such commands.
If your router leak memory, then there are some wrong. Config or try firmware upgrade.
MikroTik->Splunk
r00t
Sat Jun 22, 2019 5:21 pm
There is no such command to magically free memory. If it's being used, it's probably needed for what router is doing.
Memory might be used by some interfaces or functions (conntrack), so it's possible that disabling interfaces or some functions may free some memory, but that will also break what is router currently doing...
Or it might be memory leak and in that case you should send supout.rif to support@mikrotik.com, just talking about it here on this forum does nothing, this is user forum not mikrotik support.
CZFan
Sat Jun 22, 2019 10:37 pm
Yes there is, "/system reboot" :-)
Maybe disable services that are not being used, i.e. Hotspot, routing, etc in System->Packages.
MTCNA, MTCTCE, MTCRE & MTCINE
Users browsing this forum: No registered users and 9 guests
