amardeep704
Mikrotik API call not working
Fri Jun 28, 2019 5:34 pm
Hi Guys,
I am using the Mikrotik API (php) to connect with the gateway and enable/disable hotspot. However, the API connect function is return false.
Sample code:
require('routeros_api.class.php');
$API = new RouterosAPI();
if ($API->connect('IP', 'USERNAME', 'PASSWORD')) {
die('connnect');
Any thoughts?
mrz
Re: Mikrotik API call not working
Mon Jul 01, 2019 9:58 am
Make sure your PHP code is using new authentication method:
https://wiki.mikrotik.com/wiki/Manual:API#Initial_login
imort
Mon Jul 01, 2019 12:20 pm
Have same issue with upgrade to the new 6.45.1 firmware.
API authentication fails, and same is working with 6.44.3
Is it related with removed unsafe user passwords storage?
mrz
Mon Jul 01, 2019 12:27 pm
Yes, make sure you are using new authentication method.
Kurosudo
Mon Jul 01, 2019 12:41 pm
Same problem, i'm using same API class like you and all my systems died
imort
Mon Jul 01, 2019 12:44 pm
I think that a proper warning about deprecated API authentication with this release was at least essential.
Problem is that I have a strange success/fail API authentication entries in the logs even after downgrade and restoring the last backup.
Can you please suggest should downgrade restore old-API authentication working, before third-party software can fix it from their side?
mrz
Mon Jul 01, 2019 12:54 pm
There is already important note due to removal of compatibility with old version passwords.
Third party software should have been fixed long time ago ,new authentication method was introduced back in May 2018.
imort
Mon Jul 01, 2019 1:00 pm
Sorry, can't see anything about deprecation of old-style authentication both in the changelogs or API link you posted above.
Can you please post a link to the important note you're mention?
Thank you!
mrz
Mon Jul 01, 2019 1:04 pm
Important note!!!
Due to removal of compatibility with old version passwords in this version...
!) user - removed insecure password storage;
imort
Mon Jul 01, 2019 1:16 pm
Important note!!!
I still can't see any API-related warnings in the release.
Just to be sure that you can understand my point:
1. Removing compatibility with old version passwords
Ok, I really can't say that it should be intuitive for any user that it will affect their API authentication somehow.
2. user - removed insecure password storage;
Same here.
I didn't trying to hype on that, but I strongly believe that another important notice about old-style API authentication deprecation starts with this release will be very pleased for many MikroTik users.
Thank you.
Kurosudo
Mon Jul 01, 2019 1:48 pm
It is possible to fix it via little dirty hack in API. Just change login sequence. But This will make API usable only 6.43 higher
mrz
Mon Jul 01, 2019 2:02 pm
Not true. See how it is done in our api example client:
https://wiki.mikrotik.com/wiki/Manual:A ... ple_client
Kurosudo
Mon Jul 01, 2019 2:15 pm
Yea, i basically did same thing in my patch i just wrote "how it fastly fix".
Infact i don't see any advantage to use old style API because having unpatched ROS (pre-6.43) is big security hole
amardeep704
Mon Jul 01, 2019 6:38 pm
Hi Guys,
I am able to connect using the new authentication method. Sample code:
use PEAR2\Net\RouterOS;
require_once 'PEAR2_Net_RouterOS-1.0.0b6.phar';
try{
$util = new RouterOS\Util($client = new RouterOS\Client('IP', 'USERNAME', 'PASSWORD'));
foreach ($util->setMenu('/log')->getAll() as $entry) {
echo $entry('time') . ' ' . $entry('topics') . ' ' . $entry('message') . "\n";
} catch (Exception $e) {
echo 'Unable to connect to RouterOS.';
It lists the logs on the router.
I am trying to enable/disable the hotspot(p hotspot disable 0) but can't find the property that will be used to achieve this in the above code.
I am also trying to print the interface list but nothing ie being returned.
Sample code:
$getRequest = new RouterOS\Request('/interface/get');
$getRequest->setArgument('value-name', 'type');
$getRequest->setArgument('number', 'ether1');
$type = $client->sendSync($getRequest)->getProperty('ret');
print_r($type);
Any thoughts?
mrz
Tue Jul 02, 2019 12:46 pm
Thank you.
We will add note regarding API, too.
stealth
Wed Jul 03, 2019 12:12 am
For those who are using old good routeros_api.class.php from Denis Basta. The urls are no longer active. The needed changes to make it work again with new /login
https://github.com/Ftelf/netprovider-ne ... 73647463b3
boen_robot
Re: Mikrotik API call not working  [SOLVED]
Wed Jul 03, 2019 9:21 am
Right now, PEAR2_Net_RouterOS supports the new login method only in the development version. That is, the currently unreleased 1.0.0b7. You can only get it via Composer by specifying "dev-develop" as your required version.
Generating PHARs is a little bit difficult and time consuming right now, which is why I haven't done it yet... Since these new versions no longer support the old authentication method, I'll try to make a release this weekend.
@amardeep704 I'm surprised b6 works to be honest. As for disabling hotspot, you can use f.e.
$util->setMenu('/ip hotspot')->disable('hostspot1');
If your hostpot server instance is named "hotspot1".
PEAR2_Net_RouterOS(1.0.0b6) - My API client in PHP
(Rate my posts? If you want... no pressure...)
BinaryCrash
Fri Jul 05, 2019 8:35 pm
Looking forward to the release! :D
machack
Wed Jul 17, 2019 6:42 pm
For Login Using Php API, you need change in: routeros_api.classv1.6.php
$this->write('=response=00' . md5(chr(0) . $password . pack('H*', $MATCHES[0][1])));
for
$this->write('=password=' . $password);
Cesar Javier Robles
www.WindNet.com.ar
MTCNA - MTCTCE - MTCRE - MTCWE
benkhlifahaythem
Tue Aug 13, 2019 12:50 pm
Good day,
i did apply the new login method and i still get the same issue with V6.45.1 and up im using php .
Code: Select all
<?php
try{
$util = new RouterOS\Util($client = new RouterOS\Client('ip','user','password'));
die($e);
-------------------------------------OUT PUT--------------------------------------------------------------
PEAR2\Net\RouterOS\DataFlowException: Invalid username or password supplied. in phar://C:/xampp/htdocs/test2/PEAR2_Net_RouterOS-1.0.0b6.phar/PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Net/RouterOS/Client.php:175 Stack trace: #0 C:\xampp\htdocs\test2\example.php(8): PEAR2\Net\RouterOS\Client->__construct('ip', 'user', 'password') #1 {main}
I Don't figure it out why I'm getting the error.
Last edited by benkhlifahaythem on Tue Aug 13, 2019 3:54 pm, edited 1 time in total.
Jotne
Tue Aug 13, 2019 3:35 pm
Fixed
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
nrtszr
Tue Aug 20, 2019 2:49 pm
when will it come out?
PEAR2_Net_RouterOS-1.0.0b7.phar
thanks
BinaryCrash
Mon Aug 26, 2019 3:24 pm
thanks
I would like to know too.
mvalsasna
Mon Sep 02, 2019 11:14 am
Hi
also looking forward to the release of Net_RouterOS-1.0.0b7
thanks
MAtteo
thanks
tayyebjaved
Sat Sep 07, 2019 3:48 pm
for
Not working for me.
LeoCombes
Tue Nov 05, 2019 8:48 pm
Hi
thanks
MAtteo
thanks
UP! :)
BinaryCrash
Tue Nov 05, 2019 9:17 pm
Hi
thanks
MAtteo
thanks
UP! :)
UP!
gu1113
Mon Nov 11, 2019 10:53 pm
Hello, can anyone provide the download link for PEAR2_Net_RouterOS-1.0.0b7.phar ?
I cant see the update anywhere ... :-(
amardeep704
Mon Nov 18, 2019 4:23 pm
You can check the link - https://github.com/pear2/Net_RouterOS/wiki/Util-basics
LeoCombes
Tue Dec 03, 2019 8:23 pm
I cant see how to download phar file from the page that you suggest •`_´•
LeoCombes
Fri Dec 06, 2019 4:40 pm
I was waiting for Net_RouterOS-1.0.0b7.phar solution because I never used composer and I have not time to learn how use it, not interesed to touch and doing tests over a production server, etc.
boen_robot says that he will generate a .phar file when a new release was published, so, for those people that are waiting for PEAR2_Net_RouterOS-1.0.0b7.phar because not are a composer user and need a quick solution... here are which steps I followed in Linux:
- get another machine whith PHP installed (or install it) for generate the appropiate files, no need of touch a production server for this.
mkdir temp
cd temp
wget https://getcomposer.org/download/1.9.1/composer.phar
If you have a older PHP version (5.6 for example) maybe you will be interested in installing an older version of composer from https://getcomposer.org/download/.
php composer.phar require pear2/net_transmitter:1.0.0b1 pear2/cache_shm pear2/net_routeros:dev-develop@dev
If everything goes well, now you have a 'vendor' directory with some composer files. If you want verify that is the correct version, you can search for '6.43' in the file 'vendor/pear2/net_routeros/src/PEAR2/Net/RouterOS/Client.php' and find the new login method.
Move this 'temp' directory to your server, rename it to something meaningful, like 'composer', and include in your old script, with the correct path, for example:
replace
require_once 'PEAR2_Net_RouterOS-1.0.0b4.phar';
with:
require __DIR__ . '/../composer/vendor/autoload.php';
This is all.
electravis
Thu Feb 06, 2020 7:21 pm
I am having some issues with API login still. I have tried all that was mentioned in this form and nothing seems to be working. Has anyone had success and is able to step by step it? I updated the Basta AP.php file tried changing the variables and still nothing is working for me.
Here is the API part I think matters
public function connect($ip, $login, $password)
for ($ATTEMPT = 1; $ATTEMPT <= $this->attempts; $ATTEMPT++) {
$this->connected = false;
$PROTOCOL = ($this->ssl ? 'ssl://' : '' );
$context = stream_context_create(array('ssl' => array('ciphers' => 'ADH:ALL', 'verify_peer' => false, 'verify_peer_name' => false)));
$this->debug('Connection attempt #' . $ATTEMPT . ' to ' . $PROTOCOL . $ip . ':' . $this->port . '...');
$this->socket = @stream_socket_client($PROTOCOL . $ip.':'. $this->port, $this->error_no, $this->error_str, $this->timeout, STREAM_CLIENT_CONNECT,$context);
if ($this->socket) {
socket_set_timeout($this->socket, $this->timeout);
$this->write('/login', false);
$this->write('=name=' . $login, false);
$RESPONSE = $this->read(false);
if (isset($RESPONSE[0]) && $RESPONSE[0] == '!done') {
$this->connected = true;
break;
Then here is my test code I am using
<?php
require('ros_new_api.php');
$API->debug = true;
if ($API->connect('1.1.1.1', 'admin', 'password')) {
$API->write('/ip/hotspot/hotspot/getall');
$ARRAY = $API->read();
print_r($ARRAY);
$API->disconnect();
ANy help.
Thank you
jmmr84
Thu Apr 02, 2020 7:44 am
Hi everyone, for all of you that are workin with PEAR2 API, here is the solution:
1. Uncompress the .phar file
2. Go to the uncompressed folder -> PEAR2_Net_RouterOS-1.0.0b6\src\PEAR2\Net\RouterOS and edit the Client.php file
3. Find the _login function and modify it to look exactly like this:
private static function _login(
Communicator $com,
$username,
$password = '',
$timeout = null
$request = new Request('/login');
$request->setArgument('name', $username);
$request->setArgument('password', $password);
$request->verify($com)->send($com);
$response = new Response($com, false, $timeout);
if ($response->getType() === Response::TYPE_FINAL) {
return null === $response->getProperty('ret');
} else {
while ($response->getType() !== Response::TYPE_FINAL
&& $response->getType() !== Response::TYPE_FATAL
return false;
4. Finally make sure you have the uncompressed and edited folder where you had your .phar file and change your project's php like this:
Replace -> require_once 'PEAR2_Net_RouterOS-1.0.0b6.phar'; for -> require_once 'PEAR2_Net_RouterOS-1.0.0b6/src/PEAR2/Autoload.php';
Now you should be able to connect with the new versions of RouterOS.
afamative
Tue Apr 14, 2020 2:33 am
Good day,
Code: Select all
<?php
try{
die($e);
where you able to fix this?
christophersarnillo
Sun Apr 19, 2020 4:39 pm
Communicator $com,
$username,
$password = '',
$timeout = null
} else {
return false;
Users browsing this forum: No registered users and 148 guests
