bmatic
Script run count do not reset after reboot
Wed Jul 17, 2019 11:37 am
I have a problem that is not a critical, but just anoying. When router is rebooted script run count should be reseted, but in my case run cuont stucks at some weird number. In attachment is print screen of just rebooted router, and run count should be 0, right ?
Jotne
Re: Script run count do not reset after reboot
Wed Jul 17, 2019 11:44 am
Did test on my router.
Script Run Count did not reset after a reboot. For me it shows the number as before reboot.
This is some strange, since many have problems with other counter and variables (global) that are lost after reboot.
How to use Splunk to monitor your MikroTik Router(s)
MikroTik->Splunk
hngjared
Thu Feb 06, 2020 9:37 pm
Your script count should clear after reboot.
If not, there's a work around. You can can run a scheduler on startup to remove the script and then undo to set the counter to 0.
/system script remove "No-IP_script"
/undo
Users browsing this forum: No registered users and 93 guests
