batista
Missing script
Thu Jul 18, 2019 12:07 pm
Hello everyone.
I have unusual problem with CHR, routerOS is 6.42.3. I have write a script via winbox exactly how is described there:
viewtopic.php?t=56138
Problem is that script is gone after cca 1 hour, there is nothing when I open "scripts" tab, only in "jobs" tab I can find one process.
Why is script missing ?
In log I cant find anything about deleting script.
nescafe2002
Long time Member
Long time Member
Re: Missing script
Thu Jul 18, 2019 12:11 pm
Did you enable safe mode before creating the script?
batista
Re: Missing script
Thu Jul 18, 2019 12:18 pm
No, I have not.
I tested od RB HAPac aprox 20-times and there is no such anomaly.
Jotne
Re: Missing script
Thu Jul 18, 2019 2:16 pm
Can you try another script and see if it stays?
example:
:local test "Hello World"
:put $test
How to use Splunk to monitor your MikroTik Router
MikroTik->Splunk
batista
Re: Missing script
Thu Jul 18, 2019 3:45 pm
I tried but that script vanished just like my own...
nescafe2002
Long time Member
Long time Member
Re: Missing script
Thu Jul 18, 2019 4:02 pm
Is there anything in the scheduler?
(we're just guessing here.. might as well post config /export hide-sensitive or send supout to support)
batista
Re: Missing script
Thu Jul 18, 2019 4:26 pm
Nothing in the scheduler, empty like church in saturday night...
I have tried config script like admin and nothing change...
I will post config later.
Jotne
Re: Missing script
Fri Jul 19, 2019 9:23 am
Try upgrade your RouterOS
MikroTik->Splunk
Users browsing this forum: No registered users and 9 guests
